Back up camera...'05 Yukon... a safe location?
mountie
I am considering a new GPS. It has the option for a back up camera. The most common location suggested is a license frame mount. ..Uh, sorry,.. the camera will get destroyed there. The only location I imagine, that could be a place where the camera is protected is using the wiper 'catch'. Mount to the underside of the plastic 'catch' ? The camera would be sort of protected there.
Any ideas?
Matthew Jeschke
Sahuarita, Arizona
I never had an issue on license plate. Had mine there for years.
Otherwise I would delete the rear window snipers and put on hole from it.
Ton or work though as you would have to remove headliner to get video feed and reverse signal to the camera.
I simply ran mine down cable run at door trim on passenger side. Was a cinch. Then out a whole under catch trim.
mountie
mountie
Thanks for the suggestion....... The camera is wireless. On-off power from reverse lamp wire.
I also thought...... A hidden hole for power through the wiper catch.
Also.... here's a thought..... I don't care if it's a bit low..... Inside trailer mount... Could be a perfect spot?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Let's see a pic of the back of your truck.
mountie
mountie
Same phone, same type photo..... It says, " upload file is too large".....
I'll try again later..... ( WTF ? )
( up date).... reduced photo to a zip file... Nope..... crap
DougAMiller
Colorado
That's where I mounted mine. Well protected and I can see fine with it there.
corvette744
2004 Z-71
Northern illinois
Any ideas?
I have had my back up camera on my license plate for 3 years no problem at all.
mountie
mountie
Send it to me in a PM as PNG or JPG, or resize using Paint in Windoze.
usually, my phone takes a pic at 2.6 MB. yesterday the photo of the rear of the truck is 8.4 MB.
My phone 'updated'...... Maybe it changed the settings.... I wish these 'smart phones' just stayed more simple.
( Up date ).... For some reason the camera settings changed.... I re set it......
MassHoe04
Western MA
I am sure the camera has a pretty wide angle lens view, but under the handle has a curve, which could make the camera point more up or down than it should.
What does the camera look like and how is it typically mounted?
Pics of the camera would help.
mountie
mountie
The Garmin version is about an inch square......
It looks like you can mount it different ways.
( Since I have a TomTom, I'll check their version )......Up-date... TomTom doesn't have a backup cam option...
But this is the Garmin photo
MassHoe04
Western MA
If that clip it comes with has enough tension on it to stay put, I might try clipping it onto the bottom lip of the bumper inside the little cubby of the receiver hitch.
I kind of think it may not be springy enough to hold securely. Maybe a custom bracket bent out of sheet metal could be secured in that cubby, held in place by a spot of epoxy putty.
Other options might include:
1) Try to use one of the bolt holes in the clip and use one of the hitch bolts (if bolts will fit - possible drilling out holes to widen more).
2) Zip-tie the clip to the hitch bar, to one side of the receiver. Close enough to center... difference will probably not be noticeable.
3) Make custom bracket and use hitch bolts.
You were concerned about damaging the camera loading and unloading cargo.
I think any of the options above would protect it as much as possible, by getting it under the bumper or inside the cubby inside the hitch.
Grnt600365
Any ideas?
The plastic above the rear bumper, under the rear hatch
mountie
mountie
My thoughts exactly...... That little opening above my hitch will be the spot.....
I am sure I can fabricate something.
Rolexus
Ditto! Did much the same as you (05 Tahoe), ran cable to front under door trim, etc.. ‘Wired’ the camera cable to back-up light socket wire on drivers side - easy peasy! Have had the camera lens installed on licence plate for 4 years. Absolutely no problem - correct height and viewing angle. Lens goes out of whack occasionally - no big whoop. Sometimes snow or muddy water will collect on lens if in storm. Otherwise, no probs whatsoever!
BadDaddy2003
