Transmission fluid leak after rebuild
Geotrash
Dave
Richmond, VA
I crawled under to get a better look & snap a few photos. Found the fluid leak!
So, I estimate that repair at approximately 1/2 a$$ed. Worm drove hose clamps have no business being used on rubber transmission cooler lines. At the very least, those should be spring clamps that can maintain tension. Left alone, that connection will fail.
Good advice with the pen. I'll do that today. I've been keeping an eye on it & it's actually slightly above the "full" mark. I'm starting to realize the sweet smell may actually be the tranny fluid.
Do you guys think it's normal that those old lines keep spitting fluid?
ya if your sniffer is good enough you could be smelling the trans fluid, I did too many drugs in my youth lol I think I ruined mine
Denali12
Denali12
I tightened everything down. I’m embarrassed for them at how many turns I got on the hose clamps
I would replace that line they cut and get some quick connects and AN lines to the external cooler, this will eliminate any possible leaks in the future, I had worm clamps on mine and had the same issue
I bought 2 of these
and 2 of these to fit a true cool
and 2 of these (quick connect factory size), same as what is used on the radiator
and 2 of these
Denali12
Denali12
I bought 2 of these
and 2 of these
Are you saying replace the lines that run back to the tranny?
Geotrash
Dave
Richmond, VA
In my opinion, the metal lines themselves are wise to keep. On my 2012, I also used brass nipples with rubber transmission fluid line hose and spring clamps like I linked above where I needed to reroute lines or make new connections. I have 20K of mostly towing miles on the new cooler setup now, and no leaks or seeps whatsoever. All lines and connections are dry as a bone.
Long story short, if your rig were mine, I would replace the radiator with an OEM unit to get clean cooler tanks on both ends, then run new cooler lines from the hard lines forward to plumb everything back like factory. Summit Racing has a full lineup of fittings. https://www.summitracing.com/search...-line-adapter-fittings/fitting-material/brass
What cooler did they install when they did the work?
Denali12
Denali12
Denali12
Denali12
The invoice doesn’t say, but I remember the owner of the shop saying they significantly upsized it.
I'm driving from Key West to Nashville over the next few days so I'll have a good amount of transmission temp data.
pretty sure those plastic tabs can be removed they should only have been there to prevent damage in shipping
agmanw8n
