6.0 heads and cam
You like it? Do you daily it?
I like it when it's not running like crap, and I've been using it daily for around 2 weeks now. Do about 50 miles through local roads every day. I also have a 3k stall on it. For the most part it's ok, it lugs around under that 3k, but when I'm able to punch it, she gets up and boogies. It def isn't a Prius on gas tho. I use premium to run it, so it gets expensive.
T
Tamcphail89
I'm curious how the truck Norris will run on the factory stall. I'm not wanting to take on that task right away haha.
Def let us know when you do it. I'm wishing I went with a lower stall. It's happy spinning over 3k, and it just keeps pulling, below that it just chugs along--too much if you drive in town alot, great on the highway tho.
T
Tamcphail89
I know a stall would probably really make me happy but it looks intimidating to do lol
corvette744
2004 Z-71
Northern illinois
Im confused with when its not running like crap-are you saying with a lower stall it would be fine.I have never pulled the plug on the cam and lifters yet because of all the tuning and BS to get it right i need something as a daily and cant play around untill its perfect.
If I had to do it again, I'd go with a lower stall, but it has other issues then that. Trying to get it narrowed down. Some think it MIGHT be a problematic pcm.
Don't be intimidated. Just google local tuners and def read the reviews. Anyone can buy advertising, but reviews mostly let you know if they know what they're doing. Once you get it dialed in it's a blast to drive. You should do it.
T
Tamcphail89
Would bigger injectors be necessary? I have the factory 6.0 ones. Maybe bump to flex fuel ones?
j_jerry79
