Heated Steering wheel upgrade for 2010 GMC Yukon XL
birdhunter
Just added a heated steering wheel to my 2010 GMC Yukon XL. Purched the appropriate clock spring and wiring harness. All the steering wheel controls work, except the heated steering. The light does not even come on. Kept throwing the check engine light until I unplugged the heated steering underneath the the steering column. Any ideas? Is there a relay?
Amaster
Laramie wyoming
Hmm news to me and I added one too. My connectors a little to big so it doesn't like working. I also have had an airbag light on since then know what it for just it will get fixed eventually.
When I upgraded my 2008 Avalanche to include a heated steering while I bought the wiring harness as well and it turned out to be useless as there's a missing pin in the next portion of the harness.
I wired the green heated steering wheel into the accessory box to be on iginition and haven't had a problem since.
B
birdhunter
Did you just cut the wire from the harness and plug it into the accessory box?
Are you talking about the box left of the brake pedal?
B
birdhunter
Would you be able to send me a photo of where you placed the wire?
pwtr02ss
Tennessee
Where did you find the wheel? I've been looking for over a year. Out of stock
just needs the power wire connected, there is supposedly a brown wire down in the lower steering column area that needs to be connected to the heated wheel, you might have some luck looking on the gm upfitter guide or do as others and just connect it to accessory power (fused)
B
birdhunter
Thanks for the info.
Amaster
Laramie wyoming
Would you be able to send me a picture of where you wired the spade connectors to the accessory box for the heated steering wheel.
Thanks
[email protected]
Should be down in the upfitter box. I added mine not to long ago, I still have to mess with my ground but it's there on Yukons
FatBob
Make sure the 12v connector you choose is only hot with the key on. I picked one that was hot at all times and even with the heated steering wheel turned off it drained the battery overnight. Switched and no more drained battery
AirJordan613
Northeast Ohio
Does anyone know of more of a write-up on this? Any the parts required? Interested in adding a heated steering wheel to my ‘09 Tahoe LTZ.
Geotrash
Dave
Richmond, VA
AirJordan613
Northeast Ohio
Thanks! Called a dealer and looks like every single new steering wheel in the country was purchased and have been on backorder ever since with no ETA. So probably need to keep an eye out for a gently used wheel if I’m going to make the project happen.
Geotrash
Dave
Richmond, VA
AirJordan613
Northeast Ohio
I believe the part number I'd need is 22947767, which is out of stock literally everywhere, including Rockauto. When I checked car-part I only found one and I wasn't thrilled with the condition. Also don't want an Escalade wheel to get the wrong color backlights, which limits the search. I'm sure one will turn up eventually, not like these vehicles were ultra-rare.
Drewphil
