New to me 2011 Yukon XL Denali
J
jdwood1111
@jdwood1111 I would recommend that you either use AFM like the factory intended or you disable it, I would not recommend switching back and forth.
For $50 there is a guy that will tune your ECM for it to permanently turned off much more affordable than the blackbear tune. I recommend this more than the Range product especially if you have to smog occasionally.
If I could go back in time.. I would tell myself to skip the Range AFM disabler entirely and go with an ECU AFM delete or tune and I might have saved my lifter and cam but here we are. I wouldn't recommend turning AFM back on after having it disabled for a period of time. This all happened to me around 170,000 miles.
Also.. part of the problem with getting the blackbear tune is you have to remove the AFM disabler so that you can log data for the Blackbear tuner and this is another moment in time when my motor had to reactivate the AFM lifters. You might be able to get around this by using OBD2 connector splitter. Sorry a bit off topic.
Thanks for the reply and opinion. I agree just wasn’t in the cards but I could not find any other tuners on the site after looking so if you could point me in the direction of whom you be referring too that would be fantastic! I have called a few tuning places around here and no one knows who tunes GMs but I have a couple more places to call.
I wasn’t planning on taking it out often just ever once and a while. I’m in PA so smog once a year which for me won’t be for a while.
J
jdwood1111
So last minute we decided to take the Yukon on our trip to FL instead of the odyssey. I checked all fluids, got my emergency kit ready, aired up the spare and we are about 500 miles in as of tonight! Longest time driving the new truck since I bought it! Truck performed very well on the highway! With the range device I’m getting 16.3 mpg with 4 little kids, wife, small dog and back packed pretty good so I guess I’m good with that considering I was 70-80mph the whole time.
Here is where I’m a little concerned. Transmission at low speeds. Temps never went above 183 and shifts when on the highway we’re good. No hesitation in up or down shift when passing etc. However, low speed and mostly I think 1-2 and 2-1 are not feeling great. Could be 2-3 and 3-2 but hard to tell with kids screaming. Clunky is the best word. I know I need to do the fluid and filter but is this a sign of something worse? In and out of reverse seems a bit “strong” too. Fluid did not smell burnt and still had slight red hue to it.
Miles in the truck are 92.8k for those that haven’t been reading.
Dustin Jackson
@jdwood1111 Glad to hear it's going well man. I just took my Tahoe on a 1,100 mile road trip immediately after doing a cam and lifter swap so I know it can be nerve wracking.
Can you elaborate on your concerns of the transmission at lower speed? I don't know what you mean by clunky
J
jdwood1111
Unfortunately it was very hard to tell with all the kids in the car but basically when I was I stop and go traffic, I noticed an occasional hard shift mostly on the 3-2 or 2-1 shifts. The upshifts didn’t seem as bad. However, since this post I had what feels like a slip happen twice. This was when cruising around 30mph +\- in what I believe is around 4th and then I stepped on it would shift fine into 3rd but then seem to not really want to go in to 2nd. The first time I may have left off the gas just as it wanted to shift but the second time I did it trying to reproduce it, I thought it did it again. I am hesitate to try it again now. When driving it like a grandpa it seems fine. I unfortunately have nothing to compare it to as this is my first ever truck and GM vehicle except my first car which was a 1989 Z24 cavalier, which I loved! Lol.
When I get back from FL I am either going to do the fluid myself or have a transmission place do it and take a look/drive. It’s a second vehicle and upon our arrival home won’t be used much so I have time to make an educated/long term decision.
Edited:
So I just check the fluid again and while I can’t really read the level well but the color looks quite good to me! (See pic)This would be consistent with the transfer case fluid I changed which was also still quite red. Maybe the previous owner changed it and just doesn’t show up on the Carfax! Either way I’ll still do it just in case the filter was not changed I suppose?
if you are lucky you can just throw a rebuilt valve body/techm in it and cross your fingers, it's not a super easy fix like the 4l60's are.
not sure what he is working on there but I think you would need to drop the exhaust also
J
jdwood1111
What operations do the valve body and TECHM mostly control? Forgive my ignorance and lack of initial research but figured I would post that while I look it up. I plan on having a trans shop or two take a look and give me their opinion just debating if and when I can tackle the fluid and filter myself or have a shop do it in case of other issues. First is getting my tires dealt with and then we’ll figure out trans or the hoses I need to replace (see my other thread about my trip back from Florida).
that's what controls all the fluid pressure and has the actuators in it, the check balls shrink over time and causes issue's. on the older 4l60's you could just drop the pan and have access to the actuators right there, now it's all integrated. It's just speculation, best to have a transmission shop check it out.
J
jdwood1111
So just to follow up with this and not leave things hanging. I added about 60% (worried about it being too much) of a bottle of Seafoam Trans Tune to the transmission fluid and drove the truck about 300-400 miles before taking it to another transmission shop. First shop I took it to test drove it like a grandpa and said it was fine and the fluid was red and recommended not touching it. I then took it to another shop and he drove it without me but said he put it through the paces and it never skipped a beat. He then performed the fluid and filter service ($300) and said the pan was clear and found no evidence of any issues. He said I was on borrowed time as he does 20-30 a year of these now and says the same as all others on here, torque converters and the pumps at the bell housing. He does not rebuild them but does remanufactured units for around $3700 with a 3 year 100k mile warranty.
I have not gotten the trans temp up that hot to where I had the previous concerns but it does seem to drive better after the trans tune and fluid and service. Next up is the coolant and hoses in the spring time and hope its remains reliable!
Geotrash
Dave
Richmond, VA
Awesome! Thanks for following up!
JasonW4141
