Torque Pro APP question
rjm20
Good afternoon everyone. This is my first post. I have a new to me 2016 Yukon XL SLT. I picked up a bluetooth OBD II sender and the Torque Pro App. I am trying to monitor TCC slip.
I can see and add the TCC slip gauge to my APP but the reading is always blank. Like it is not picking it up. Does anyone else have the TCC slip working for a 6l80? Did you have to use custom PIDs? Any tips you have would be appreciated.
PatDTN
I discovered that not all OBDii readers are created equal. I don't remember what my first one was but it was very limited. Luckily I managed to lose it and was all prepared to buy a really expensive one. I searched online and found reviews that pointed me to a really cheap one that's way more capable.
R
rjm20
I am not in love with the obd2 dongle I have. It doesn't have a switch so the light ways stays on. I'll order a different one and see if that works. I am still in the return window on the first one.
R
rjm20
Ok just scrolling Amazon it's hard to know.
Does anyone have a link to an obd2 do gle that they can confirm reads tcc slip on a 2016 ish Yukon? I'd prefer one.that shuts off when the truck powers down but I can always buy a switched extension
I've been thinking about looking at the same thing. I have come across a master list before and was able to select some seldom used sensors to watch but they are not always active or should I say, constantly being updated. My vehicle is also the previous generation.
Next time out I'll take a look. Ken might know as well. @kbuskill
St. Louis
I have the OBDLink MX+ adapter which is pretty expensive now, but when I bought it a few years ago it was less then $100. It shuts down after a few minutes of the car shutting off. I don't know about the TCC slip as I've never looked for that, but I can look later today.
Welcome to the Forum from NH.
Pics of the truck, please.
St. Louis
I added the built in TCC slip gauge that Torque Pro app comes with and it just read 0. I'm not sure what the PID # is or if the header just needs to be changed in the "modify PID parameters" or what.
I do know with my BT Dieselworks AutoSync I can bring up the slip reading in the DIC and it also shows whether the converter is locked or unlocked
R
rjm20
Thanks for looking. I have an old scangauge that would show the slip on my 07 Silverado. I tried it on the Yukon and it does not work. I am trying to avoid the $100+ sending unit when the $23 one I have works for everything else.
I am thinking of modifying an extension cable to power the power lead from a switched power source. Or just leaving it always on... Don't know how much effort it's worth to have it turn off.
You might try to look up the specs on your Bluetooth OBD dongle and see if it goes to sleep, and/or what kind of mA draw it has while the truck is off.
St. Louis
Or just unplug it and set it in the cup holder or door pocket before getting out of the car
PatDTN
I don't know about the rest of you guys but I can barely remember to unplug mine right after I use it. Come to think of it my first reader was probably still plugged in on the Sierra I traded for my Tahoe. 7 years ago.
Mine has an annoying flashing blue light when it is connected to the app, because of this I almost never forget to unplug it! Almost never! LOL
R
rjm20
I could unplug it and likely will when -30 and I leave the truck out over night. Which is seldom to never
R
rjm20
So no one monitors tcc with the torque pro app?
Spent a good 30 to 40 minutes with it today looking through all the PIDs to see if it was listed. Didn't see it. It may not be listed in the ECM but the TCM which either the app or adapter cannot see.
I have monitored this function before with the Tech-2, will pull it out next and see where that is located, ECM or TCM.
albac
