I made garage bling out of those rims.
You'll also like not having the snow build up on the running board under the door from the front wheelsInstalled a set of Husky mud flaps. It will be nice not to have slush mounds and mud splatter built up on the fenders/rockers/running boards/exhaust tips.
View attachment 376310View attachment 376311
Looks good and you will get less slush now that you are lower.Installed a set of Husky mud flaps. It will be nice not to have slush mounds and mud splatter built up on the fenders/rockers/running boards/exhaust tips.
Any chance you got a part number? Also, what exhaust kit are you running - I really like the look of the dual tips?Installed a set of Husky mud flaps. It will be nice not to have slush mounds and mud splatter built up on the fenders/rockers/running boards/exhaust tips.
Here is the flaps:Any chance you got a part number? Also, what exhaust kit are you running - I really like the look of the dual tips?
Here is the flaps:
Tips. Yeah they look much better than the factory ****** berry and adds a very slight growl. Very happy with them. Easy to install:
SLP 31059 Dual Tip Tailpipe Assembly + Free Shipping
Buy SLP 31059 Dual Tip Tailpipe Assembly: Exhaust Pipes & Tips - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I got a set of those wheels too sitting on an upper shelf in my garage...Kept them in case I needed to resort to snow tires-so far, so good!
No it's fine. I like to listen to it with the r/r window down to it underload next to a barrier or wall. And cold start. It is really subtle.Is there any extra drone in the cabin with that SLP tip?
Did you have to cut the pipe or will I get lucky with it as a bolt on?Here is the flaps:
You have to cut it mid way down over the rear axle. I’ll find the video for you when I get a chance. Really you can just eyeball it if you are mechanically inclined. Hardest part is getting the rubber hanger on the new pipe it’s not a 100% alignment.Did you have to cut the pipe or will I get lucky with it as a bolt on?
That looks pretty good. I wonder if they have anything for my 02. The fronts are good, new bottoms installed, but the middle row is getting bad with my Malamute’s claws doing damage. Nobody sells the replacement covers for the middle row seats.I fixed some scratches on my passenger seat. These were probably caused by some web gear or suspenders during hunting season. I used an autoleatherdye.com kit. So far I only did that center panel where the scratches were as a test. You have to put the dye on THIN to prevent plugging up the holes. I put on two THIN coats. It came out pretty well.
View attachment 376317View attachment 376318View attachment 376319
