Can Someone Please Help Me With Headlights!?
T
ThreeD
( just learning here)..... I'd like to see a pic of that 'fence pattern' the lights display.
Adjusting will change where the pattern is pointing? I thought installing bulbs is just 'push & turn' into the socket?
That is what I thought as well, but I have been reading that new headlights must be adjusted. I don't think I have ever had to adjust new headlights before. I will get you a picture when it gets dark.
If the OP is still referring to LED headlights, see post #12 for the adjustment positioning of LED headlights.
Jimmyy
Minnesota
Could the pattern be from the light bouncing of the chrome trim? They look nice and bright. I bet your LED's would look good in these as well. Can you post a shot with them against a garage door or wall? There are some good videos on how to adjust the headlights on a 99 on YouTube.
T
ThreeD
Here are some pictures of the beam patterns. The first two pictures are low beam and the last two pictures are high beam.
T
ThreeD
Yea, I will try and get a picture of the beam on a wall later today or tomorrow. It’s raining out at the moment. When you say the light could be bouncing off the chrome trim, is that something that can be adjusted? Thank you.
T
ThreeD
No, I am using Sylvania XtraVision halogen bulbs. Can LEDs be used in OEM GM housings? I didn’t know if they could, so I just got halogen bulbs. Thank you.
Jimmyy
Minnesota
Unless they are pointing down I don't think so. Check on YouTube there are a few videos showing the light output. On one that I watched the guy had similar light close to the front. It didn't have the same pattern as yours but it did have some lines.
T
ThreeD
Do you happen to have the link, or what did you search for? Thank you.
east302
Mississippi
That almost looks like some issue with the lenses maybe? Got a picture of the headlights?
Stock GM would have had “Sylvania” stamped on the face of the lens.
kwhaleys
