How would I install a Aftermarket deck with Factory bose
2003tahoe4
Well I just sold my chevy truck 2003 model without the bose, well I have the harness to retain the chimes and stuff, well The tahoe I will get will have the factory bose in it, now I will be using external amps for all my sounds, so will I have to worry bought the bose at all, I want to just bypass it all, just run the rcas to the amps, then speaker wire to all my speakers, will this be fine or is there a special way that I have to do to cut out the bose?
TnTahoe
TN
i think u can just use the box to retain the chimes and rap then just run everything as planned, but im installed an aftermarket hu but im not using a harness so i will no longer have the chimes
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
Peripheral Electronics - GMAA, you can stack them IIRC to get Front, Rear, and NON fading Full range RCA OUTs... PLus amp turn on leads
At that point though you are better off getting a double DIN head!
you can also use a LOC after the Bose amp which is far cheaper.
2003tahoe4
well I Do have a double din a kenwood ddx-812, well I was just wondering if the bose has its own harness to the radio that I can just leave out when I put in my deck, the only wires ill need to use on the deck harness is the red accesory, ground, yellow 12v constant, illumination, and remote turn on for my amps, i wont use any speaker wire from the deck, cause my amp will run all the speakers,
AV8ter
I am really interested in this too. I am helping Narco get a system in his Tahoe with stock bose and onstar.
He is going to run an aftermarket headunit(most likely Alpine single din) and a 6ch amp to run all the speakers.
So now I have some questions. Does the door chime and or onstar come through the door speakers or does it come through a separate auxiliary speaker?
He is dead set on having them still function but I don't blame him. I know people do aftermarket headunits and aftermarket amps all the time but I can't seem to find a solution/example on how to keep the chime/onstar.
joechatham69
Smithville, TX
U can find the speaker wires that go to the bose amp under the center console cup holder. Just unplug the harness at the amp and tie speaker wire into the wires that go to the speakers and run them to the four channel amp. There is no acc going to the factory hu. You will have to run ure own from the radio to the main harness under the dash. I think the wire is gonna be a fat pink wire, but i cant remember for sure. Use a meter and check. its really not as hard as it sounds.
fire730
Louisiana
I have to wait until I can get home to look up the numbers but a friend of mine that is an installer just gave me the 3 adapters I need for my 04 Yukon to change out the headunit and keep my steering wheel controls, the chimes and the BOSE/Onstar. I am going to run an aftermarket amp for all of my speakers but I still want the factory sub in the console to work.
Tahoewhat
Ballin' on a Budget
TX
so much easier to just run all your own wire into each door for new speakers and leave the bose harness intact,
Im keeping my factory nav, and adding a amp to the door speakers, i have bose also, Im still confused on how to do this. I have a loc for my 2 subs, and have another loc 4 i think, so i can do all my doors, but how would i go about putting a amp to them, instead of the bose?
Sorry if that sounds confusing, mine is thinking more than i can type..
thanks
2003tahoe4
Ok I think you guys are explaining how to just re-use the factory bose speakers and sub, adn just bypassin the bose amp, well I wont be using anything bose, or onstar, ill be running aftermarket speakers, with there own wire ran from the amps, I just wanted to know how would I have to install my deck, harness wise, basically i want to unplug the bose stereo, and the bose speakers to take them out so if I ever sold my hoe, all i would have to do is re install the speakers and factory deck and plug back in the bose, I just want to know if i would have to install my deck a special way, wire it a special way
TnTahoe
TN
ok if you dont care about the chimes and stuff, the only thing you will need to do is basically find a power, switched power, and ground
If you want I can show you exactly how I wired mine and I still have the RAP
hassoun
Germantown, MD
you pay more for the truck because it has bose. then you decide to swap amps and disable bose! lol. personally, i'll never swap bose with something else. the stock system in my Denali is was more than enough. i just added two subwoofers,a monoblock amp and a decent alpine headunit.
2003tahoe4
yea I just wanted the lt with leather so most have bose, yea man show me how u wired it please, basically yea I just want to just retain the chimes
SQNALI
Fort Collins, CO
Dunno if your still planning on doing this however, I have retained factory head unit and amplifier/door chimes/etc with the use of the JL Cleansweep. Its capable of using a high level (post amp) input and providing RCA outputs - whilst leveling the sound frequency band over volume. Check out JL's website for more info BUT its more or less a kick a$$ version of an RCA line out convertor.
What Im getting at is not using the new head units RCA's, instead tapping off post bose amp for RCA out, and if re-install of factory system was required, you would have to reconnect 4 channels (8 wires).
TnTahoe
TN
you cant retain the chimes without buying some type of adapter, but you can retain the RAP features with just wiring
Eickybobby5050
