2010 Passenger power windows stopped working....
peterbrown77
But the driver's side is okay. Replaced the DDM and reprogrammed it but still the same issue -
I can hear the relays click on both passenger doors from the DDM.
Any thoughts or prior experience?
TIA
P
peterbrown77
The DDM can only operate the drivers side windows, front and back. I only get clicks from the passenger doors. All door locks and mirrors work from the DDM. Passenger side windows unresponsive to any window switch but I hear them click as if there is no power to the pass side regulators. Replaced and programmed the DDM with Delco techconnect
Dave S
Broken wire in the harness is where I would look. I have found ground and power wires broken in two. Most recently on the DR side. Same symptoms. 3 years ago the ground and then 3 months ago the power.
P
peterbrown77
And it was a blown 60A fuse that supports the 4 25A breakers in the driver's footwell. I'm suspecting a mouse under the fuse block over the left front wheel.
veteran111
