George B
¯\_(ツ)_/¯
I tawt I taw a wocketman…What’s with the broken windshields down there? Must be a Texas thing.![]()
You did, you did see a wocketman!I tawt I taw a wocketman…
My mishimoto just started leaking exactly where you described your cold case is leaking at. I'm pretty pissed at 14 months it's leaking and I'm not even saying what I paid for it .... I'm not sure what my next move is yet with mine
Damn. I heard about the aluminum radiators having issues and not lasting long but I figured the Cold Case or Mishimoto wouldn’t fail. Kinda glad when I replaced the one in my NBS for maintenance I decided to go with OEM. The original one lasted 150k and 18 years and was actually still good when I pulled it. Even with a blower I never overheat and have hauled some heavy trailers too.My mishimoto just starting leaking and it's 14 months old
Those aren't big enough. The center hole in these wheels measures about 3-3/16", or 81mm diameter. I'll get some cheap plastic caps that size to try out the look.Here it is:
2007 CHEVROLET TAHOE 5.3L V8 Wheel Bearing Dust Cap | Shop Now at RockAuto
Brake & Wheel Hub Parts and More for Your 2007 CHEVROLET TAHOE at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.www.rockauto.com
First Pic is single speed transfer case knob.
Second pic is two speed transfer case knob.
Two speed has 4low
For snow and other "minor" situations where 4HI will work. Those usually also have 3.08 gears too.Single speed..
Why?!
Having 4 low makes the whole setup![]()
Now you can take them 120+ mph turns betterIt was time to replace the end links, bushings and washers were done for.View attachment 372562View attachment 372561
All my women are the same way too! LOLI had this rental "dodge Nitro"
neat suv, kinda fun to drive
real nice exhaust note for factory, shifting was also pleasant.
Felt like it cut the ignition for each shift, reminded me of a motorcycle I had where the shifter hit/wore through a wire and would short out the ignition each time I up shifted.
Anyways, it had a few "woman" features that i remember.
One of those was this "2wd / 4wd" selector.
Hit me as a grocery getter, for woman only.
but then again, ours has that "automatic" selector option that is 100% for the woman that has noidea how to deal with the extra options.
My wife likes that very much.
She likes hers where it's AWD even more, no thinking just drive.
I was just going to write the same thing! LOLNow you can take them 120+ mph turns better
I have the 2 speed in my 2001. I personally haven't been in a situation where 4 hi didn't do what I needed.For snow and other "minor" situations where 4HI will work. Those usually also have 3.08 gears too.
I've been needing to do that too. I've put it off hoping I can figure out a way to turn it into a disconnect-able link for all that front end travel. lolthey were just worn out I tightened the old ones up about a month ago because I was getting the clank-clank noise but it didn't help much I think those mevotech were about 3 years old, maybe a little more
One of the things I noticed as a snowbelt traveler, when I get down south l, is you guys have way more debris on the shoulders and along the centers and the medians. Up here they have to plow snow and usually the snow acts like a sweeping compound and sweeps all that debris way off onto the shoulder and way into the median so we don’t have as much debris to kick up into windshields.Or a southern thing? The safety manager at work said he's had to replace more windshields in our vans in the south than anywhere else. He assumed it's the type of roads/aggregate we have here. I'm guessing our roads differ from those where it gets colder? I usually get a new one every year or two, at most. I wait until my inspection is due then get the new windshield and sticker at the same time. Then see 'em 12 months later cuz I'm sure to have stars and cracks all over, including in my field of vision.
