Just Fishing
Can't fix stupid
Control arm's probably won't make it for today, but my new lifter pre-load sounds amazing.
Yes. They all do that after a few years. The ones on the avalanche are way worse than that. Replacing them in a month or twoIs this "dry rot" around the outside tread of my tires? All 4 tires look the same, it's only along the outer tread. The rest of the treads have life left, but the manufacture date of these tires are 2016.
We plan on taking a road trip next month. Was planning on getting new tires afterwards, but now seeing this, I might do it before hand. View attachment 371866
Stupid tab broke off the dash trim so I drill the hole and zip tied it to the main dash. Going to need to order some parts…
@iamdub remind me how you supported your center speaker…
That was @Doubeleive ,I do believe, lolStupid tab broke off the dash trim so I drill the hole and zip tied it to the main dash. Going to need to order some parts…
#metooI had at least 10-15 of those notices and a couple more came after I had it done, lol
If you pull the speaker out and look down in there it's not a flat surface under there it's angled a bit so I just cut some styrofoam to fit so it would support the bottom of the speaker and I put epoxy around the screw mounts for the speaker because they crack as well. They must have had the village idiot design the dash and then chose the cheapest vendor for the plastic. I mean it doesn't take a scientist to figure out hey this might break from bouncing around going down the road, maybe I should brace it, hell even a single stock of plastic under it would have helped.Stupid tab broke off the dash trim so I drill the hole and zip tied it to the main dash. Going to need to order some parts…
It is the worst design! I had the speaker out but ran out of time to do any more. I will come up with something some other day. I might squirt some expanding foam into a ziplock and let it self level…If you pull the speaker out and look down in there it's not a flat surface under there it's angled a bit so I just cut some styrofoam to fit so it would support the bottom of the speaker and I put epoxy around the screw mounts for the speaker because they crack as well. They must have had the village idiot design the dash and then chose the cheapest vendor for the plastic. I mean it doesn't take a scientist to figure out hey this might break from bouncing around going down the road, maybe I should brace it, hell even a single stock of plastic under it would have helped.
Where'd you get the blanket that's around the battery?All buttoned back up and all maintenance done, so unless something flat out breaks then she should be good to go for a long ways View attachment 371953
it's a corvette battery cover/insulator, I think I have both battery's wrapped in insulation also, it's my feeble attempt to try and keep the heat deflected.Where'd you get the blanket that's around the battery?
Awesome job on figuring out they can be swapped. My passenger side is like new. I may do the sameDoing the seat back cushion swap. Very easy.
View attachment 372020View attachment 372021View attachment 372022View attachment 372023View attachment 372024
Looks good, mine are worn, scratched and smoke style on black truck, were there when I bought it.
Thought I would post an update. Back in March i asked Gruven about it and they offered a refund on the gears, but I already had it JB Welded on, so. I noticed last week that the seat does now lift with me sitting on it, before I would have to stand outside. During installation it did not seem to bind. My guess is the motor was weak and has recovered.I replaced both the foam and seat cover. I sit about 1" higher now due to the new foam.
Bummer though. That gear I showed was for the driver's rear end seat lift. I replaced with Gruven brass gears. Doesn't seem to be binding, but it seems the motor doesn't have enough oomph to raise my 195Lb butt. I have to stand outside to raise the seat. Goes down with my rear on it. Do the motors get weak?
Buy a Lube Locker gasket for the rear. $21.95 at SummitLast weekend
New parking brake shoes, tire rotation, oil change, greased the brake caliper slides.
Still going to need to order new calipers(they've been squeaking most likely because the dust seals on a couple of the Pistons are torn and filled with a brake dust and dirt and whatnot.
Found the rear diff cover leaking-potentially a broken seal... have to find out if tightening the bolts down health or made it worse. Use the felpro gasket, but when I tightened it down it looks like it started to squeeze out. Unfortunate the 14 bolt doesn't have the rubber and steel reusable gasket like the 10 bolt.
Engine oil cooler lines seem to be leaking somewhere on the short little rubber lines.
The starting battery needs to be replaced again. My fuel line for the flex fuel sensor needs to be remade-seems to be seeping fuel occasionally. Found a lower control arm bolt a bit loose also.
