Lifted/Leveled 2021 - Postem Up
flyfaster1
Which wheel are those?
Nothing fancy.. I’m ready to replace or repair the wifeys wheels without throwing down a ton of cash.
Gear Offroad 766B Gloss Black 20x9 6x135 6x5.5 +18
Nitto Ridge Grappler LT285/60R20
Yukonxl21
View attachment 369426View attachment 369427A new 2021 4x4 2021 High Country with 22s for wifes xmas present.. I wanted something a bit different but she wanted another one blacked out, minus the bronze on the front grill and bronze painted calipers. Now on a set of 20x9s, 3.5” lift and 285/60/20s. Full front, side mirrors and rear PPF, and finishing up the sides. Corsa sport with blacks tips sitting in the garage. Need to black out the side marker lights and rear, lower reflective lenses.
Sick wheels, which ones are these?
sanman28
I thought I’d post mine up since I’ve asked a million questions on here. See if I could help someone else with questions. I ended up just doing the lower strut spacer (said it was 1.5”) with 18x9 method 316’s and 285/70/18 Nitto Ridge Grapplers. Zero rubbing but I’m very very close to the liners…I think I pushed the limits and barely got away with it.
Offset?
LekGMC
I’m not 100% sure. I do know that Method only makes one offset option, for this wheel, in an 18” with our lug pattern. I remember that there wasn’t any options. It was just this one…so whatever you punch in on the method site, just pulls up this
sanman28
How is the brake caliper clearance?
Gkacp
Here is my 2021 z71 Tahoe.
Running a 2inch Switch Suspensions lift in the rear and 2.5 in the front.
17x8.5 Method 316s on 315/70r17 BFG K02 A/T's
The suspension was stiff at this height on stocks but with meatier tire rides the same.
sanman28
Best so far. How bad do they rub?
VAguy68
I'd like to see more pics and get more info on the lift. Yours sits just right!
olyelr
Elk Rapids, MI
Nice!
Looks good for sure. Not sure i would like driving around with the bags mostly fully inflated though.
Im amazed that 17’s fit !
Gkacp
Nice!
Yeah, it's definitely a risk but it's one that I'm okay with being the guinea pig for. Also yeah only some 17s fit, when I was looking my selection for 17s was almost halved for them to fit the tahoe.
sanman28
What criteria on the 17’s?
Gkacp
honestly, I'm not too sure, wheels that are the same backspacing and offset don't fit as these do. I would just check with the manufacturer of the wheels you are looking at to see what they say because from what I've seen it's not a numbers thing.
olyelr
Elk Rapids, MI
Yea, i suppose even if the width, backspacing and offset was identical it could still come down to the designs of the wheel and how it was made…as far as fitment issues go around brakes and such.
a1parrothead
