Engine swap '04 Tahoe 5.3 to 6.0
mattt
I figured I'd start an engine swap thread for future reference and for others who want to do the swap in the future. I'm about half way thru the swap process. The old still running well 335k miles 5.3 that leaked oil prodigiously is out, and on a tire and pallet. The 6.0 is on the stand and waiting to go in while I clean up the engine bay with everything out.
The 6.0 was sourced from a Pick Your Part junkyard from an 04 Yukon Denali LQ4 with unknown miles. I ordered a complete LS "rebuild kit" from WS6 Store that came referred on LS1Tech.com. Everything looked okay internally but the unknown factor led to a full rebuild, .020" O/S flat top LQ9 pistons, full cylinder head rebuild & bowl blended ports, w/ Smith Bros trunnion upgrade. The builder surmised the CR would be 10.3:1 or thereabouts after the machine work on the heads and block, along with the head gasket used. Summit Racing truck cam 8718R1, small-ish side to keep it more sleeper, and be daily driver & tow rig friendly. LS6 valve springs. Luckily the LQ4 I started with has the later Gen 4 rods with removable piston pins w/ circlips. Had those "rebuilt" with new pin bushings and the .002? O/S bearing. Crank and block was checked, decked, and refurb'd. New oil pump, bearings, hardware, etc. I had the long block professionally assembled by a local engine builder. New GM knock sensors & harness, new GM motor mounts
I have a couple questions on subtle differences noticed between the original 5.3 flexplate and motor mounts. Picture 1 shows the 5.3 with flexplate still installed and the flexplate that was on the 6.0, that came from an 04 Yukon Denali. Does it matter which one is used with the 6.0 and the original Tahoe trans? Bolt patterns seem to be the same, but the "window" cut outs are a bit different. Is there a difference in flexplates from 5.3 to 6.0 or 4L60 to 4L65? I know from my Ford days, there are different offsets & imbalance in Ford flexplates depending on engine family and year model. Is that the same case with the 5.3, 6.0?
Is there a strong reason to not re-use either of these used flexplates? What about flexplate hardware....is it single use like TTY head bolts or is it acceptable to re-use flexplate bolts?
With the motor mounts the heat shielding is different from old to new. The new ones were bought from Ebay from a seller in Ohio for $41 each that claims these are new, un-used take off GM motor mounts. The part # on the sticker is correct. Did GM change the heat shield on later year motor mounts? My original 04 motor mounts have the straight tin, metal heat shield as opposed to the wrap metal foil heat shield seen in the picture? Any GM motor mount experts can say by looking at the pic?
Mudsport96
40.923,-89.488. Illinois
I am pretty sure 60 to 65e there shouldn't be any offset difference. Maybe someone that knows that swap better will post. As for balance that doesnt matter since you opted for different pistons and such, the factory balance is out the window anyway
In the earlier models, pre-dating yours, there was a flat flex plate and spacer to make up for a .400" shorter crankshaft. Both of your flex plates should have the same amount of dish and the crankshaft should have the same reveal between the two engines. My initial thought is to use the one from the 6.0. Measure where the 5.3 flex plate is in relation to the bellhousing mounting surface and compare it with the 6.0's flex plate mocked up to the 6.0. I bet they're the same.
As Tony mentioned, some people have issues with them cracking. Personally, I don't know of it as being a "common" problem, at least not on stock vehicles. I can see F-bodies, etc. cracking them. I'm inclined to think it might be due to hard use/racing and/or worn trans input bearings allowing radial movement in the torque converter.
You can re-use those bolts if they're in good shape. They're not TTY. Mind the sealant/thread locker.
If you got genuine GM OE mounts for $41 each- score! The heat shield did get updated at some point, but I thought it was later, for the Gen4. If the bolt holes, critical dimensions, etc. all match up, they're good to go. Actually, the newer design looks more compact so it should fit better.
rockola1971
Indiana (formerly IL)
Flexplate is the same for 60e/65e tranny AND 5.3L and 6.0L (Except for the first 2 model years of the 6.0L which are 99-00. The reason why 99-00 flywheel is not compatible with the 5.3l is because the 99-00 6.0L crank snout at the rear was longer. Otherwise 4.8L,5.3L,6.0L,6.2L are all compatible. (Excluding transverse Front Wheel Drive cars)
tRidiot
Excellent information that should be put into an easy to find place - I think this came up during my motor swap, too, and took some research to track down.
M
mattt
They are the same dimensionally from what I see measuring. From what I was told on LS1Tech for some reason, unknown to me, GM used a different flexplate for the 6.0/4L65e vs the 5.3/4L60e configuration. Yes I've seen one of the flat flexplates on the early "iron head" lq4 and the crank difference is an issue if you want to stuff that engine in front of a 4L60 or 4L65. It won't work. That early lq4 only works with a 4L80 behind it.
Cool thank you for confirming on the bolts. Would you have a recommendation for sealant for those bolts, the oil pressure sending unit, and the coolant temp sending unit? I'd like to replace the O-rings on the other sensors as well but GM doesn't offer the O-rings separately. Gonna have to go on the hunt. I'll check the flexplate for cracks, but I think I'm gonna run the original 6.0 plate.
They are dimensionally the exact same, just the heat shield is different. Already bolted them up and all is good. I may run by a dealer and ask for a 25828247 and see what comes out just to confirm that part # looks like the ones I received. I suppose it's not out of the question that in 18 years GM changed/updated the heat shielding on the motor mount. Yeah, they seem legit and the seller has 100% positive feedback. I'll find out over time. Here is the listing for them. https://www.ebay.com/itm/313323450385?hash=item48f3887011:g:oUkAAOSw~8FfxS4E
Your stuff is all within the same generation so you're good to go.
I've always used a healthy coat of blue Loctite on the threads. Never a problem. Some use red, but blue has always held just fine, especially with all the threads coated. Using red might cause problems should they ever need to be removed. Since sealing is also part of the reason for using it, you wanna use a lot. You don't wanna use a lot of red. Be sure you clean the holes in the crank flange very well- brake clean, wire "pipe cleaner" brush, dry with compressed air, more brake clean, etc. I've never reused oil pressure and coolant temp sensors and the new replacements come with dry threadlocker on them. I'd imagine a similar sealant would be fine, but don't completely coat the threads since the sensor might use the block as a ground.
M
mattt
Going thru things today since my buddy wasn't able to help drop the long block in the Tahoe today. I was looking at part of the engine wiring harness and a question came up. Is the engine harness all one piece, including the lower portion that wraps around the oil pan up front and grabs the starter, oil pan sensor, A/C compressor? Or is that lower part sub-harness separable and connected to the main harness somewhere with a connector? Asking because if it were replaceable, I'd be considering replacement on that lower part.
I've dealt previously with Mustang 5.0 EFI harnesses, and there are 3 separate harnesses that inter-connect with Q/D plugs making up the complete engine harness.
Is the '04 Tahoe engine harness all one piece or are there possibly connection points that I missed? Thanks.
tRidiot
I believe it's all one piece... seems I saw a replacement new harness available recently for a coupla hundred somewhere.
This may have been what I found - I probably would have considered it when doing my motor swap, had I known it was easily replaceable.
M
mattt
Steam line poll: What is the consensus on which steam line is better to use, the 4 port from earlier 99-00 vehicles, or the block off plugs in the back of the cylinder heads and the standard '04 front steam line that vents the heads up front?
I have both available. Anyone venture a guess why GM didn't continue the 4 port steam line like the earlier vehicles had?
One piece.
I'm with @Mudsport96. I've read that it was a harmless penny-pinching move. The 4-port is better, but not necessary. If it were me, I'd use the 4-port if it were available. Especially on a performance-oriented build. I'm keeping a look out for one and have spare gaskets on hand for that magical day when I find it.
M
mattt
Thanks for all the replies above guys.
For future reference on engine removal, I meant to post up in the first post that you can in fact remove a long block engine(block, heads, balancer, flexplate) without dropping the front axle, or removing, disassembling the front core support. All other ancillary parts were removed with the engine in place, intake, exhaust, accessories, water pump, etc. It was extremely tight coming out, distance wise between the core support and the back lip of the engine compartment(above the firewall setback)....like an inch or less. But it will come out.
I removed it with a forklift and lifting straps which probably helps too, since the forklift can lift straight up and down and tilt when necessary. That in contrast to an engine hoist which lifts in an arc motion. If you remove the balancer, it will come out with a ton of extra clearance.
M
mattt
Been having a harder time lately finding time to dedicate to the reassembly, but finally had a free afternoon to get after it. Working on the reassembly today and have a few tech questions, from deep in the weeds.
I've seen two different style exhaust manifold bolts, 1 with a smaller head and 1 with a larger head. I'm guessing they were updated by GM to try to stop them breaking off in the cyl heads. Which exh. manifold bolt is the better, or newer of the two? Just about ready to reinstall the exh manifolds. Is there any factory manifold that is a better choice, perfomance wise, than the standard truck manifold off the original 5.3? I'm not sold on changing to headers at this point, from a cost standpoint and the fact that they heat up the engine compartment.
I've seen replacement studs & hardware available for the outlet side of the exh manifolds. Is replacing those a "gotta do it" thing or will the original rusty ones live on for another 300k? The nuts took forever coming off, but no thread galling or breakage.
The original crank position sensor and cam position sensor were functional when I tore everything down. I looked at replacing both with GM parts but GM is pretty proud of those things now. Last time I had looked they were ~$50 for both IIRC. So I guess I'll be re-using my originals. However, I'd like to replace the O-rings to ward off any oil leaks from these 2. Anyone have a part # or O-ring part # for these two? I found a seller on Ebay offering a replacement for $20 but figured I'd see if there is a common O-ring I can source locally?
Thanks all!
M
mattt
Let's see some pics or description of gussy'd up engine compartments. I regret not painting the block now, but what's done is done. However, I've been considering spraying some paint color on the accessory bracket after seeing how much better a fresh coat of black paint on the balancer looks.....nevertheless, seeing the balancer once installed is fleeting. If you spent some time with paint or other details in the engine compartment, let's see. I'm all eyes on suggestions. Thanks again.
Thanks all!
I'd go with aftermarket exhaust manifold bolts, possibly ARP. I bought some stainless #8 bolts iirc from Michigan Motorsports.
If you're not sure about the O rings, if you have a Harbor Freight locally they sell a whole O ring kit with a bunch of different sizes for a really reasonable price.
JamesinAbilene
