ivin74
05 NBS Nali
I'm going with the 2020 setup. I got the rotors & calipers off a wrecked 2020 Silverado.
What you end up paying for them?
I work slow also. You didn't wanna chop a hole in the floorboard for easy access?Almost half way. I'm in no hurry and work slow and deliberate.
$150 for the rotors and calipers. Truck had 44k miles on it when it went boom. The pads still had 50% life or so but I just got some new PowerStop z36 pads.What you end up paying for them?
The first time I dropped the gas tank (replace fuel pump) was a little bit of an adventure that I crawled through slowly.I work slow also. You didn't wanna chop a hole in the floorboard for easy access?
Hit up @ScottyBoy- he sells used OEM ones that he’s cleaned up and re-loomed plus he can instruct you on how to install it. I tried a couple aftermarket ones and even beefed one up and it still melted. No problems since going to the OEM harness and relays.Whos up to date with what EFan harness to buy? Pretty sure the PO that wired mine screwed something up and its causing the driver-side fan relay to burn up. IIRC the Nelson performance harness has been known to have issues, anyone know if an OEM one is available?
Thank you for the response I specifically remembered you having an issue with them at some point and figured youd know the ultimate solution!Hit up @ScottyBoy- he sells used OEM ones that he’s cleaned up and re-loomed plus he can instruct you on how to install it. I tried a couple aftermarket ones and even beefed one up and it still melted. No problems since going to the OEM harness and relays.
Edit: it looks like you have the OEM relays which are part of the OEM harness so I’m not sure what’s up. Have you looked at the thread in the tech section that shows how to wire that harness? Iirc all there is to connect is power, ground, the green trigger wire that goes to the pcm, and the 2 plugs on the fans. There isn’t much to screw up. Maybe you have a fan going bad? Try switching the fan plugs so that relay runs the other fan and see if the other relay melts.
second time around is always faster, you know how to get that job done already. hardly have to think about it really lolThe first time I dropped the gas tank (replace fuel pump) was a little bit of an adventure that I crawled through slowly.
But the second time I dropped it (to run new brake lines) the whole thing took 15 minutes, and most of that was using a little transfer pump to move gas into a can.
Exactly. I already rehabed the tank straps nuts and bolts, and all the hose connections were cleaned from the first time, and I even remembered how to get my arm up inside the frame to squeeze a disconnect.First time is a learning experience and takes longer. And the second time around everything's been apart already, and what's going to break has broken.![]()
I do have a couple spares, but I'm sure the cost to ship one to you would make it more cost-effective to do some local junkyarding...... I'd also love the OEM fusebox cover that has the second cover for the fan relays, its a pita to pull the entire box everytime.
Have you checked to see if your wheels clear? It’s been an issue for lots of people.View attachment 368341View attachment 368342View attachment 368343
Almost ready for the big brake upgrade
This one had me flummoxed for a while - the one still connected in the picture. I used my Lisle tool that worked on the filter and the lines to the rail but it didn't seem to work. Gave it a couple days of thought and some helpful chats with @Fless who presented another possibility - to remove those lines from the tank and leave them on the body. He also requested pics of the lines to help future TYF folks. After taking a picture, I pressed on the line and heard a click. Damnit, just needed a firmer tug...lol. Was able to disconnect it successfully.Exactly. I already rehabed the tank straps nuts and bolts, and all the hose connections were cleaned from the first time, and I even remembered how to get my arm up inside the frame to squeeze a disconnect.
