2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Stupid TPMs sensors must have low batteries out of the box. Tried holding for up to a minute to get them to connect and all I get is the red “low BAT” light flashing.
Oh well, atleast the sunset was pretty and the weather is great. If I didn’t have a sinus infection I would have started the front main seal swap.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I've also read that some new sensors will wake up with a rapid deflation or inflation. Apparently they can be shipped "asleep."
Huh I guess I can pump up to like 60psi and then let them drain really quick. Of course none of the amazon reviews say anything about any of this.
pwtr02ss
Tennessee
On the avalanche I have to hold the lock and u lock button on the key fob at the same time and the horn beeps. Front driver tire until the horn blows then work my way around the vehicle. Move the tool around, even pointing it at the valance stem from the tread side of the tire, or straight down behind the valve stem. The first time I used my tool I couldn't get it to work. I followed the directions, nothing. Started moving it around the tire and it started working
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I have to move mine around too. Just when I think its not working, it works.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I’ve tried moving the programmer around the valve stem and even touched it to the stem, tire sidewall, and wheel itself hoping it would work but nothing.
What I’ve been doing is as follows. Turn ignition to on
Cycle headlight switch from parking lamp to off four times. After the fourth time the truck honks and flashes the tire low light repeatedly telling me it’s in program mode.
Then I go to the driver front tire and point the scanner at the sensor while pressing the button on it. Nothing happens even after a full 1-60 Mississippis. I’ve tried starting with different tires as well but no luck.
Then I get mad and give up.
pwtr02ss
Tennessee
That would put me well into the teens on how many times I’ve tried.
Try it flat against the sidewall. Or pointing directly into the tread of the tire. Read the reviews from your specific purchase. They have tips (what I did after I tried mine and got pissed and threw it in the tool box).
pwtr02ss
Tennessee
Also, go behind the valve stem on the wheel and point directly at that. It seems every tire on my Yukon required something different this last time I did it
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Guess I’ll try these tomorrow but hopefully at lunch I can get to discount tire where they should try to program them for free.
HeavyHoe03
