Charlie207
LFOD, New Hampshire
flushing the power steering fluid seems to have resolved the noise problem (whine), it's been a week and it hasn't made a peep since
How much new PS fluid did you need to have on hand to complete a successful flush? I'm putting this job on my list of spring cleaning.
I used just under 1 gallon, I ordered (4) 32oz ac delco fluid and I still have a little bit left in one bottle, after about 3 qt's it starts coming out pretty clean looking, I usually do that annually but I skipped last year and then it started whining at me about a month or so ago while near full lock
Just Fishing
Can't fix stupid
Utah
So I have one TPMS sensor that stopped working on the Acadia. I have the tool to relearn them and tried to do a relearn but that one sensor doesn't respond.
I called a local tire shop asking if I could just drop off the wheel and have the sensor replaced and they want $85.
Seems kind of pricey or is that about a normal fee to break the bead on 1 side and replace the sensor?
I'm not sure how much they cost, but look up the cost of an oem sensor vs an aftermarket one.
Eta: i see that was covered.
I have to do this on the tahoe once it's back on the road.
I think one or two are weak, and once i rotated the tires, the connection will randomly drop...
Just Fishing
Can't fix stupid
Utah
What is the process for this?
I think that was the powersteering fluid flush.
I went through a good 4 quarts before mine looked good.
After driving for a while, it needs to be done again.
Lots of sludge in my pump, part of why I'm adding a filter adapter for the return line.
ETA: I read that wrong, see what Rocket Man said below.
I made a little hose extension to get the hose out of my wheel well
Do it with the engine off. ;)
I disconnected the return line at the power steering pump and used a rubber cap to plug the nipple on the pump, then used a barb to connect a long hose (5/16” or 3/8”?) to the rubber return line and put it in a bucket. Then with the front on jack stands, I turned the wheels from lock to lock without starting the engine. Keep topping the reservoir, make sure to not let it run dry and get air in the system. Keep doing it until the fluid runs clear. Some videos I’ve seen show them starting the engine but I don’t think it’s necessary and requires 2 people.
Don’t remove the high pressure line or you’re f*cked lol. That’s the one with a fitting you have to unscrew.
St. Louis
usually takes me at least 3 qt's for it to start coming out clean looking
DOH, I thought he was asking how much does the power steering system hold!
You guys actually disconnecting the line and draining it then refilling, or just sucking the reservoir out and refilling/drive a bit/repeat?
EDIT: DOH, I see you explained your procedure in a later post, lol
Not today but did do both hubs actually not that bad of cost. The stock ones did there job and lasted 160k + haven't given her a burst of highway to see if fixed my issues.
What brand did you go with? As you noted, OEM hubs usually last 150k or more. Timken are what most of us use, they make a some of the OEM hubs on our trucks. Detroit Axle has a bad rep, there’s been catastrophic failures and there’s no telling how long they’ll last.
Amaster
Laramie wyoming
Oem Ac Delcos. I know Timken weren't a bad option either. but yeah, I heard Detroit axle aren't very good.
13UpInSmoke
Used Moog hubs when I just replaced mine, along with their upper control arms
Phlipnstik
