If you watch the show you will see the devastation that it caused via aerial views and close ups. You will see videos people shot while they were driving thru the fire to escape.
They are a sponsor for the forum. They have a section at the top with the codes listed.After much investigation and having to measure the extended length of the strut supports, I came up with AC Delco number of 510-1227 and GM number of 19324360. RA does not have in stock at this time. They will notify me when in stock. I do not have access to all my 5% discount codes that I can use in the future, so could someone here supply me with code(s) for that discount? Or does someone have another source? I did check both numbers at Amazon with no luck at all.
Did you try GMPartsDirect.com and GMPartsGiant.com?After much investigation and having to measure the extended length of the strut supports, I came up with AC Delco number of 510-1227 and GM number of 19324360. RA does not have in stock at this time. They will notify me when in stock. I do not have access to all my 5% discount codes that I can use in the future, so could someone here supply me with code(s) for that discount? Or does someone have another source? I did check both numbers at Amazon with no luck at all.
I just got that code, thanks.They are a sponsor for the forum. They have a section at the top with the codes listed.
19324360 is $28.46 each at GM Parts Direct and is $26.38 at GM Parts Giant but were around $25 ea at RA plus the %5 discount but since are not available at this time, the part listing and price are not showing at this time, so I am guessing at the price at RA. Since I get in the back rarely, I will wait and see if RA gets back to me.
Ordered the Strongarm ones off of RA for $10.52 each and used the 5% RA discount.OEM ones weren't available 1+ years ago when the ones on my rear glass failed. I got Strongarm off ebay for $18.76 for the pair. No problems, not even in ~30° temps.
Mine has the power liftgate, so I can't speak for those struts.
Had new rear emblems prepped and installed on back of my Z71. The BOWTIE/TAHOE one on the driver's side is all blacked and outlined with white and the CHEVROLET one will have that done as well, likely next week. Thoughts?
Back somewhere in this thread, I have a blacked out front BOWTIE in the grille.Non-factory appearance mods?! Who are you, and what have you done with Ron?!
I can always change to a matching silver color but thought I would try the white first. I believe the entire pic of both with the white will be fine. If look at post #693, the white looks better than stock, IMO. Along with the Escalade rear appliques, I believe the entire pic will look great.Not a huge fan of the black/white but thats just me.
I think that Ron is gone. Maybe, its the impact of his new interim location. I don't know who this imposter is.....Non-factory appearance mods?! Who are you, and what have you done with Ron?!
