2007 Suburban 2nd gear vibration
stocksj
Brandon, FL
Hi, I getting some slight vibrations in my 07 Suburban when down shifting going through 2nd gear. The new to me SUV has 149k miles. Otherwise drives great. No issues accelerating up through the gears. Could this be a electronic issue or is the transmission starting to go?
Thanks
wjburken
Eastern Iowa
Thanks
Set your DIC to show if you’re in V8 or V4 mode and see if the shudder lines up with the switch to V4. My guess is you’re feeling when the AFM is shifting from V8 to V4 mode.
stocksj
stocksj
Brandon, FL
Hi, I did some checks today on the drive home and that looks to be the problem. When in V4 slowing down the vibrations start. What’s the best fix? Delete the DOD? Or could it be a solenoid in the transmission?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Delete tune or bypass it with a Range device in the OBD port.
stocksj
stocksj
Brandon, FL
After a good bit of thinking and getting tired of listening to the transmission shuttering I bought the Qzucar AFM delete module. Installed it this morning and took a test drive, Now I know how the Suburban is susposed to drive. rides nice and I feel I can "get on it" without feeling the transmission may break. I paid $115 for it on Amazon.
scottd
