'07 Yukon XL Tailgate not going up/down via power
BSarteSr
Read through several threads about tailgates going up/down but they all seemed to be about the lift shocks or the latch. My '07 Yukon XL Denali is not raising nor lowering the tailgate with the power from the motor.
I can raise and lower the tailgate manually and latch/unlatch without any problems. When I try to use any (remote, handle, or front button) power function (up or down) it just makes some noises like it is trying to open/close the tailgate.
Any pictures or videos for some instructions on the liftgate motor/mechanism.
Big Mama
Virginia
Sometimes one of the buttons gets stuck and the others won’t work. The other threads you refer to may be talking about the lift struts versus the ones on your glass. Check the wiring where the lift gate meets the body. They’re known to degrade.
BSarteSr
BSarteSr
I checked the console switch but now you make me want to go back and check it again
Big Mama
Virginia
Hopefully it’s that. If not you might start looking at the lift gate motor.
BSarteSr
BSarteSr
Nope, double checked, moved the position of the console switch from auto to manual, back to auto testing in between changes, could hear the motor trying to something.
Now I have to figure how you remove that side panel, looks like I have to take the whole lower half off to see what is going on with the motor.
Anyone know of a YouTube video that cover that for an '07 Yukon XL?
Big Mama
Virginia
You’ll take the back inside panel off and you’re right it’s a little bit of a pain. I haven’t looked for a video but I wish I had. Start with the clips on the inside around the edges with a pry tool and work toward the middle. It’s been so long since I replaced mine I can’t remember how I finally got it off. We have the same rig.
wjburken
Eastern Iowa
Look down along the lift bar on the passenger side and see what the motor is doing when you press the button. You should be able to get a decent look by holding the rubber flaps back. Could very well have some issues with the gear drive on the motor.
wjburken
Eastern Iowa
Check out the video I posted here.
Should be able to just pull the rubber gasket back a little and see the motor and if things are turning or not.
Here is a video of a guy working on the liftgate.
BSarteSr
BSarteSr
wjburken:
Did you make that video?
I watched it (excellent video) and got the panel side panel off, disconnected the computer and took the whole motor with brackets off/out.
Learned the hard way that I need the computer hooked up to the vehicle to be able to open the tailgate latch because I did not take the tailgate cover off, so I had to crawl back in from the front to reconnect the computer so I can open the tailgate. LOLLLL
So now I have the motor out and wondering if their is any way to bench test it? Probably not.
Any suggestions?
BSarteSr
BSarteSr
Hooked up my scanner, just like I thought, did not tell me anything so I have a mechanic who says his scanner will read everything, even open/close doors so have to wait to Thursday to bring it over to him.
Will update this thread when I learn more!
wjburken
Eastern Iowa
wjburken:
Any suggestions?
No, I did not make that video. I ran across that video when another member was having issues and I tried to find some information to help them. Knock on wood, I have not had an issue with the tailgate lift on any of the Yukon's/Suburban's that we have owned of this body style.
I would think that you would be able to "bench test" it by hooking it up to the vehicle with the lift bar released and watching it operate. Otherwise, if you can figure out the wiring, you could hook power to the correct pins for lift and for close.
BSarteSr
BSarteSr
OK, some very good updates....
Took the Yukon over to a guy that does work on the Yukon at times and he put it on his SnapOn Scanner, 2 interesting codes:
B153A Liftgate Latch Switch Signal Circuit Signal Invalid (symptom 08)
B153E Liftgate Position Sensor Signal Circuit Signal Invalid (symptom 08)
At 1st glance it looks like this issue is the Liftgate Latch on the tailgate......
Wondering about the 2nd code? Is that the sensor on the motor for UP/DOWN positions?
BSarteSr
BSarteSr
Not sure where the issue is and hesitant to buy a new GM Lift Gate Latch, seems like part #15839037 is the correct one, so found a 2013 one, going to give it a try to see if this is the issue.
BSarteSr
BSarteSr
OK, got the lift gate latch, came out a late model Acadia. Took about 30 minutes to swap them and it works now.
So now I know what the symptoms of the lift gate being bad is......something I really did not need to know but you know how that goes!
Greaser007
@BSarteSr - I had to respond to your Tailgate Latch / Liftagate Latch thread posing.
I just did fix my wife's 2007 Suburban powered liftgate which suddenly quit going up on about May 03, 2022. Great Scot.
So, after hours of scouring the net for wiring diagrams for circuit chasing, I came across this Posting of yours.
I disassembled both the Liftgate motor-drive mechanism, and checked the solenoid clutch for operation and the gear teeth, with all lookng newish. Solenoid clutch electrically operating just fine. ( reminds me of an a/c clutch ).
So, here is the hard cold truth:
I took my wife's '07 Suburban 2500 4x to the local dealer and was quoted $1,785 smackers for new Liftgate assembly, Latch and struts. Technician indicated liftgate motor failure and latch and struts. OMG
I am 70-years old, and my dad was a lifetime gm parts guy, so I am used to considering parts Interchange.
I ordered GM part #84243380 Liftgate Latch from RockAuto and was delivered yesterday at 11:30am.
I unpacked it this morning and took me a whopping 20-minutes to install. I pushed the upper console switch from 'disable' to operational position, pushed the lift actuator switch and the Powered Liftgate unlatched and went up as it should like Normal. Yeeeeaay. :) big smiles.
For those concerned or having powered liftgate / tailgate problems here is the deal. (my conclusion) read below.
I disassembled the latch assembly looking for a switch which communicates sending a signal to the module attached to the Liftagate assembly. I was able to only remove the electric motor and bull-gear (ring-gear white plastic). All was good. I couldn't disassemble anyfurther, so no evidence of the "suspect switch" communicating with the liftgate module.
Now that the powered Liftgate Latch / Tailgate Latch is operational again, I'm going to perform "Open-Heart-Surgery on it to find the ghost switch which is apparently not working.
An electrical switch can only open and close a certain number of times before the contacts become corroded or compromised and fail to make a good connection.
Relay's go bad because they are an electrically operated switch closed by a solenoid activated by the switch circuit.
Each time I have had a Relay failure, and circumsize off the plastic cover exposing the contact points, they operate as designed once cleaning the point contacts.
We can do this in an emergancy on-the-road if you have a hacksaw blade to cut and remove the relay cover.
Easy Peasy.
Moral of this comment:
If your powered Liftgate or Tailgate is not powering-up, chances are the hidden switch in the Latch has failed.
Today I am One-Happy-Camper. :)
Geotrash
Dave
Richmond, VA
Easy Peasy.
Yes. I recently replaced mine in my 2007 as well, after first taking apart the lifting motor and gearbox and finding no problems. When you finally find the offending switch with the gummed up contacts deep inside the latching mechanism, please do let us know so I can take my old one apart and fix it to have a spare.
Coolman1987us
Maine
I'm about to tackle this problem also. Pretty sure I have the same problem.
worleytrev93
