Mine also just “passed” inspection but that’s all I’ll say about that...
Agreed that they are scams
The things we do for dark tint, eh?
Fubar0715
Scott
Southern New Hampshire
Found an overhead console with garage door controls built in for a reasonable price (not the assinine pricing others are trying to get *above $125**) and installed. Easy Peasey! I also found the cable for the auto dim mirror (fingers crossed) up there so well be on the prowl for that next. The SSV is slowing getting civilized and not the hot mess we find them in. :D
alpha_omega
Michigan
One of the things I'm imparting to our kids is how to keep an older car running reliably and bank the money they save.
That should be an absolute must these days. It seems like 3/4 of the younger generation has no clue what’s going on, no drive to work, and expects free handouts for the rest of their lives.
I wouldn’t be throwing around the idea of that potential purchase if I didn’t already have my ducks in a couple different rows providing security around our nest egg. I was never one to live on “borrowed money”. That’s not to say that the wife and I don’t have good credit or CC to use in a pinch if need be (outside of using them for rewards points), but I wouldn’t use them or take out a frivolous loan for something like that.
Our motorhome was twice the cost of what the Denali will be, which was one of two aces I held when I originally had this discussion with the misses. The other being that we spent that much on the horse I bought her plus the cost of one years worth of training and vet bills. Since I don’t ever do much for myself and since the purchase will be made from extra assets in our checking account it won’t be detrimental to our retirement. And since you can’t take it with you, why not enjoy it while we still can?
Geotrash
Dave
Richmond, VA
Sounds like a rock-solid bargaining position to me!
When Cadillac announced the CT5V Blackwing was available to order in 2021 (the one with the V8), I went to my wife with a copy of Car and Driver and said "I WANT THIS CAR!!!" She said, "I think you should go buy it." Bless her.
But in my case, all I had to do was run the numbers of what it would really cost us vs. how much I would really gain from enjoying it. To do that required me to reflect on every other time I made an impulse buy for a car I was drooling over (new BMW, new Land Rovers, etc) versus how much I'd actually enjoyed them, and that was enough. I put my checkbook away. :)
cmatt
Need some radiator advice. At 152k, it looks to be the original rad. I’ve been suspicious of a small leak. Did a pressure test at 15psi (overflow tank cap says 20psi) and it appears to be leaking at the driver side. Are these prone to leak here? I drove it approx 10 miles round trip and didn’t experience a large coolant loss. Just trying to figure out if I’m shopping for a radiator@swathdiver
Geotrash
Dave
Richmond, VA
Yup, they sure are. Looks to me like it's time for a new one. Go OEM unless you tow a heavy trailer.
alpha_omega
Michigan
Ha! Gotta love your relationship with the wife during times like these. I’m not familiar with the Blackwing time to do some research. Plus that means you owe us a photo of the one you were daydreaming and drooling over.
Very true! That’s and not being 100% sold on the new look is why I haven’t bought one yet. Instead I’ll just keep investing in and driving Omega (a few times a year) until that time comes.
alpha_omega
Michigan
For towing heavy, do you then suggest either the Coldcase or Mishimotos that several of us have discussed extensively in the other thread?
Geotrash
Dave
Richmond, VA
Here it is right from the configurator :)
Geotrash
Dave
Richmond, VA
I have a Cold Case in my 2012. It's a 2-row with oil and transmission fluid coolers in the end tanks. The 6.2 generates more heat than the 5.3, yet uses the same cooling setup from the factory. I've found that it's not adequate for towing near the limits in hot weather in the mountains (7,000 lb camper, 90ºF+ outside temps). I was seeing coolant temps of 240º+ in hot weather over the hills with the factory radiator (via OBD2 port), and with the Cold Case I see 210-220ºF in the same conditions.
Sparksalot
Bastrop County, Texas
I just put a Coldcase in thecopcar. I had it in 2 days from Summit, and it bolted right in. My original burst in the middle of Big Bend after only 203K of break in service. Same tank btw.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Just serviced my baby. Oil and filter change. Remember my oil drain plug got stripped out at the service shop and it had heli coil stuck on it? I confirmed there are no heli coil pieces stuck in the hole. It's completely stripped out smooth and measures .460 on the dial caliper. Now I have to research a repair for this. Anybody been down thus path? I am hoping not to use helicoil again, seeing as it already failed. Drill tap the hole for a bigger bolt? Or some kind of threaded insert?
I also changed the air filter with a Delco replacement. Of course I forgot to plug the MAF sensor wire back in. So it threw codes P0102 & P0113. This also caused the service stabilitrac and service traction control warnings. Of course I panicked with all the lights and bells going off. Started to loose my cool, had to pull the Fonz out and chill. Realized "Hey jaggazz, you forgot a plug." Plugged it in and cleared the codes and all seems good. So future reference if anybody else goes through this.
Either the HeliCoil wasn't done properly or it was buggered up beyond that kind of repair. Mine has been HeliCoiled since before I bought it. Works fine.
Your best course of action depends on how bad it is. Personally, I like steel threads over aluminum. You could try repairing the thread (new HeliCoil). If that doesn't work, drill and tap it the next size up and use a larger plug and just be careful when tightening it.
89Suburban
SE PA
Appreciate your response. Next question is, there is no room for a drill to fit in there between the pan and the chassis. Thoughts?
Must be a 4WD thing. Not even a right angle drill would fit? Hazard Fraught has one for about $20. It looks like a weak POS, but you're only drilling aluminum, and just enlarging a hole at that. You might even cut the bit down some.
Perhaps the next size up is an SAE size and yours is already stripped out enough that it wouldn't need drilling and you can just tap it.
V8Soulja423
