New door stickers - how do you do it?
Kapitein
The Netherlands, Europe
I think I might know the answer to this (im screwed), but hey, I figured id try the forum, maybe theres hope.
I need a new door sticker, the one with the VIN and the vehicle weights on. Im trying to get my XL Denali correctly registered here in Europe. At the moment im only permitted to tow 3300lbs with it, and I want to get this increased to the normal 7900lbs.
Part of the paperwork process requires info from the door sticker. My current one is *****.
Is there any official way to sort this?
Wouldn't a photo of the RPO codes in the glovebox serve as an official way to get the paperwork processed? It has the towing-related codes that translate into specific maximum towing weight numbers for the truck.
There are companies that do reprints. Grab one off the internet and put your VIN and production date on it. It does not however, specify the tow rating so not sure what the government is looking for unless it is in the VIN in some database. What year is your truck?
Kapitein
Kapitein
The truck is an 07 Yukon XL Denali. Max trailering weight is 7900lbs.
The problem I (mainly) have is that its a government organisation - so common sense goes right out of the window.
What I need is a 'statement of masses' I found 2 companies that can provide this. Vintage vehicle services in Canada, and VDocs here in Europe.
Ive tried with Vintage vehicle services and I just cant seem to pay them! They process payment only by CC (locally, on a merchant machine) and none of my 3 credit card companies here in Europe will allow the transaction, as they deem it potentially vulnerable to fraud.
VDocs require a picture of the Door sticker (amongst other things) in order to produce the document I need). The DMV equivalent here also asked to see the door sticker, but I get the feeling they might be a bit more flexible.
Ive provided them with the RPO codes, the official GMC trailering guides and specs, the owners handbook, even the sticker on the hitch... all to no avail. What they want is a document, with the VIN number and some sort of declaration saying the truck can haul 7900lbs.
My route to that involves my door sticker, which I typically dont have :(
Blackcar
Try.https://autodatalabels.com/
That label does not say your truck can haul 7900 pounds. Also, in 2007 a Yukon XL Denali was rated for 7,700 pounds. Only your owner's manual states what the maximum towing capacity is in that year and the Gross Combined Weight Rating (14,000 pounds) as well.
From your owner's manual:
Kapitein
Kapitein
Seems autodatalabels only sell to autobody repair shops, plus you need a photo of the original sticker, which I don't have :(
You are going to need to do some photoshopping to get a replacement made.
Perhaps this document may be helpful.
  • 2007 YD Printbook for RPO Codes.pdf
Kapitein
Kapitein
Strange. The 07 spec sheet and trailering guides list it as 7900lbs. 7700lbs would also be fine for me though... I just need more than the current 3300lbs
Hey Joe, where did you come across this document? Would be nice information to have for my 2013.
I found mine by simply Googling it. But, I think that I was simply lucky that someone else had already posted it.
But, I just did a search for you folks, and I came across this:
How do you get GM build sheet?
Send an email to [email protected] , include your name and your vehicle's VIN and they will email you back your build sheet in PDF form.
I have not personally tried this, but I would think that this is worth a try for you folks.
In the glove box there is a sticker showing the VIN and the RPO codes
contact gm on the gm website 9am-4pm usa eastern time via the gm website, select your brand, then select chat. the chat representative can email you your vehicle build sheet
print your build sheet from home it will show the vehicle information
your build sheet will show the axle ratio, the sticker in the glove box (with vin) will match it
take both to the dmv with page from owners manual showing the axle ratio towing capacity with the above matching info.
it should be as simple as that. the sticker in the glove should be fine alone but sounds like we are not dealing with smart people.
Kapitein
Kapitein
Situation solved... I think.
Finally managed to get payment to vintage vehicle services in Canada, and hey presto! A statement of permissable masses with the VIN.
Thanks all the info, was a great help. :)
Thank you for posting the solution to your issue.
JeffK
