kylebnoris
- Joined
- Dec 29, 2023
- Posts
- 55
- Reaction score
- 52
Alright gentlemen, this is my progress on my EBCM debacle and I'm grasping at straws now to find a solution, so hopefully someone can assist.
I have a 2005 Tahoe Z71 4x4 with the stablitrack / JL4 EBCM module.
We replaced the module due to no communication with the scan tool.
We had success with a JL4 module from an 05 Escalade, and have a line of communication with the scantool to perform bidirectional diagnostic and testing.
However, we have a intermittent ABS and Parking Brake Light on the dash, as well as a constant Traction control light.
From what I understand the module needs to be flashed / programmed per the VIN of the truck. The serial # and part # on the Escalade was exactly the same as the one that came off etc.
So here's my nightmare. Locally only two shops can program the module. One cost $400 and one cost $200. Both have informed us that if the flash fails, that it's a non-refundable deposit. That it doesn't matter if it's a Used module, remanufactured, or a brand new one from GM, that sometimes it just fails to take the flash and that we'd be out of the money and forced to find another and try again. Dealerships are all telling us it's too old to work on, and apparently this programming has to be done VIA OBD and cannot be done on a bench so it has to be physically installed and functional on the vehicle.
So my question is, should we take the risk, or should I try to purchase SPS2 / Acdeleo TDS / RAP2 ($3,000) Jesus) and attempt the programing myself? Is that even possible or will I need some sort of verified dealership key for it to even work? Or are we royally screwed here and left to this weird racket of a module programming network.
Thanks for all the help. I can't wait to post the final build sheet for this truck after it's done. Close to $10,000 in repairs, all for my buddies Later fathers truck to now serve him hopefully another 185,000 miles.
Thanks, this forum is awesome!
