RooTBeeRthe1st
E85 ~60% per my sensor
= $2.68
Premium 93 = $3.88
Here in Arlington TX lol
I haven't checked my percentage in a while.
Not sure what the abv is lol
The physical sensor is ridiculously more accurate and quick though...10/10 would do again.
Edit
Last fill up is almost 75% during the Harsh SoCal winter. Lol
Probably going to be what appears to be a brass onion -- er, union -- with a lot of barbs. Not sure if that little gray tool is to disconnect the quick connect or help install the union.
First pic I've seen of the whole shebang. I'm not even gonna begin to guess what that gray thing does. Unless it is split and opens to fit over the tubing, I don't see how it could be a release tool.
Oh well, Pawpaw is covered one way or another with his orders.
@Fless called it! Double male barbed coupler and a release tool. For the tool, I've never had one of these let me down: https://www.amazon.com/ARES-70024-3-16-Inch-Scissor-Disconnect/dp/B0195XBPPQ
Although, you won't be needing it to install your repair parts.
If it weren't for ethanol, I'd pick the double barbed fitting over the compression union, unless that double barb is stainless. If it is zinc-coated steel as it appears to be, you did good ordering those plastic compression unions. If they ever leak, get stainless double barbs.
RooTBeeRthe1st
7444 bulbs
The turn signal definitely let the smoke out.
The DRL uses the same, but white. Because SSV, I swapped the white drl's into the turn signal spot for now.
See if I can find any leds i like i suppose.
RooTBeeRthe1st
Finally modified the dust covers on the headlights to clear the leds.
Even with all the rain we've had, they never fogged being open.
After the car wash they did though.
Made sure not to offroad until I closed them up too.
Also adjusted the hood stops, hoping that's been my "front end clunk".
Some how this morning, I magically missed that bump during my commute that always makes the noise.
So I'll have to try again tomorrow morning I suppose.
7444 bulbs
Aren’t those your new AlphaRex headlights? Seems fishy that a bulb would already burn out.
agmanw8n
