RooTBeeRthe1st
E85 ~60% per my sensor
= $2.68
Premium 93 = $3.88
Here in Arlington TX lol
I haven't checked my percentage in a while.
Not sure what the abv is lol
The physical sensor is ridiculously more accurate and quick though...10/10 would do again.
Edit
Last fill up is almost 75% during the Harsh SoCal winter. Lol
Probably going to be what appears to be a brass onion -- er, union -- with a lot of barbs. Not sure if that little gray tool is to disconnect the quick connect or help install the union.
First pic I've seen of the whole shebang. I'm not even gonna begin to guess what that gray thing does. Unless it is split and opens to fit over the tubing, I don't see how it could be a release tool.
Oh well, Pawpaw is covered one way or another with his orders.
@Fless called it! Double male barbed coupler and a release tool. For the tool, I've never had one of these let me down: https://www.amazon.com/ARES-70024-3-16-Inch-Scissor-Disconnect/dp/B0195XBPPQ
Although, you won't be needing it to install your repair parts.
If it weren't for ethanol, I'd pick the double barbed fitting over the compression union, unless that double barb is stainless. If it is zinc-coated steel as it appears to be, you did good ordering those plastic compression unions. If they ever leak, get stainless double barbs.
RooTBeeRthe1st
7444 bulbs
The turn signal definitely let the smoke out.
The DRL uses the same, but white. Because SSV, I swapped the white drl's into the turn signal spot for now.
See if I can find any leds i like i suppose.
RooTBeeRthe1st
Finally modified the dust covers on the headlights to clear the leds.
Even with all the rain we've had, they never fogged being open.
After the car wash they did though.
Made sure not to offroad until I closed them up too.
Also adjusted the hood stops, hoping that's been my "front end clunk".
Some how this morning, I magically missed that bump during my commute that always makes the noise.
So I'll have to try again tomorrow morning I suppose.
7444 bulbs
Aren’t those your new AlphaRex headlights? Seems fishy that a bulb would already burn out.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
7444 bulbs
Strange that the DRL has a dual filament bulb. :oops:
RooTBeeRthe1st
They are, and it does. Maybe it was a cheap bulb, maybe there was extra load or something from poor connections, no clue. Slightly annoying though.
Damn GM engineers expected light bulbs to last longer than the vehicles apparently. Since you have to pull a damn bumper to change a headlight bulb. Lol
RooTBeeRthe1st
I'm assuming that it was just easier for them to manufacture that way. Use the same dual filament for the turn signal and the drl.
Drls online are useless anyway, their programmed out of the bcm, there's no way to ever turn them on.
89Suburban
SE PA
I just got those push fit union connectors, they are the shit. And the quick release works well. Very cool! I think the barbed fittings maybe aluminum, they are very light and non-magnetic.
RooTBeeRthe1st
You guys running E85 whats your average mpg vs the 93?
I only have 91 Cali cat piss
But, e85 my normal commute 8-8.5
87/91 about 10.5 if I remember correctly. Been a long time since I ran it and tried to calculate the mpg.
All highway e85 ~11
87/91 ~14
Geotrash
Dave
Richmond, VA
The term “salt truck mechanic” makes me cringe and reach for a BFH to fix any problem you run into. Michigan winters play hell on vehicles, I do my best to limit my driving during those months (all ten of them), or at least give them baths often.
When I moved from Colorado to Virginia back in 2020, it was a huge deal to me for the main reason that I would now have to deal with corrosion on my cars. I HATE that. I grew up in Pittsburgh, and was so happy to live in dry country Colorado after college. Of course, as I write I'm sitting in Columbus, OH with our previously pristine, Arizona-owned for most of its life, '07 XL Denali sitting outside drenched in salt spray. I can almost hear the rust eating away at that clean metal.
Ralph Turner
