Just Fishing
Can't fix stupid
Utah
Yours has a #2 thrust bearing? We might've found your problem. lol
Even the stock LMG, at 9.6:1 compression, benefits from 89+ octane. At least, during hot weather. If you lowered the CR of your 6.0 to something more suited for ~87, you'd lose a lot of the peppiness you have now, even with the tune optimized.
You can change the cam without removing the heads by removing the rockers and spinning the cam a few times to push the lifters up into the trays, then sliding dowels (5/16" works fine) into the oil galleys to hold them while you swap the cam. Since you already have your rockers removed, you could slap on them 1.8s. Just be sure of your geometries. Oh, larger than stock cams tend to sacrifice small amounts of low end for mid-and upper-RPM power. That's just physics. They need a higher SCR to achieve a net DCR to make up for the losses. So, keep your CR and quench where you're at, unless them 1.8 rockers put you in the PTV danger zone.
Lol no i replaced it once already.
rolled in place and was able to set and confirm endplay from under the truck. :jester:
And yeah, i don't want to change the config and how it runs.
Just Fishing
Can't fix stupid
Utah
I'm pretty happy with the cam i have now, I'm happy with the low end.
Biggest complaint I had with the 5.3, low end power sucked balls.
With the 6.0, even with the timing pulled way back, the low-end was very nice. :boobs:
And the 1.8 ratio rockers went in with the AFR heads install / engine build. :thumbsup:
Full rollers.
Decided since i went with those fancy heads, i might as well make use of the more lift.
+ AFR recommended rockers with roller tips.
Part of why I'm being so **** about checking the oil filter and not willing to run it too long.
I have a ton of money in this build, and i do not want to get metal in the brand-new parts.
But yeah, the more i think about it.
I should just pull the engine this time around. ugg.
I'll pull the pan first either way,
Then i can check out the crank, and it's easier to unbolt the converter that way anyways.
Bill 1960
Testing the Limits
Just Fishing
Can't fix stupid
Utah
I just finished building a 6.6L and I have close to 200 miles on my build. No noises or anything. I however didn’t reuse anything except my oil pan. Everything is new. Block crank rods the whole nine. My build when finished tuning should make around 750ish to the wheels.
If the surface on the polish is rough or turned the wrong way the crank journals now have like a circular saw blade effect on the bearings. It has teeth going into the turn instead of laying on the turn. This will most definitely eat up a bearing.
Think of like sharpening a knife. The tip rolls on the opposite side of the sharpened side right? Now has what we call a burr. Same applies to crank polishing. The burrs still exist after polishing but you need them to be roll over on the rotation not against the rotation.
There are tons of videos online that show this in great detail.
This is why when shopping around for machine shops you need to be mindful of experience and word of mouth not lowest price. Just making a statement. Don’t read into it.
I hope you get this fixed.
Just thinking about this...
I'm curious how the tuning differs from the stroker crank (iirc that's what you're doing).
If i have to replace the crank anyways...
but then i'm looking at new pistons, but that's doable.
got a build thread, or just going to continue the current one?
Things for me to think about.
:hmmm2:
We could be build buddies!
(not in a creepy way, but maybe)
mad ryan reynolds GIF by 20th Century Fox Home Entertainment (GIF Image)
08z71bgm
Long Island, NY
:hmmm2:
Only thing you change is cylinder volume when you change displacement!
I used all summit pro ls stuff! Quite happy with the quality and balancing. No Mallory needed. Bought a whole rotating assembly in 4.0 stroke and bore. Brand new ly6 block too.
Forgot to add that my whole valvetrain is stock gm stuff. No high lift cam here. 558/553 lift with 1.7. Didn’t want the lope or valvetrain issues with high lift cams and tons of long life and mileage from oem parts.
Just Fishing
Can't fix stupid
Utah
Happen to have a link to the parts? ;)
Just Fishing
Can't fix stupid
Utah
I bought everything from summit racing. Only one kit 58x 4.0 stroke and bore. Comes with bearings and everything. Upgraded to the tool steel wrist pins. They said to be 1000 and over it would be required. So for only like 30 bucks it was worth the upgrade.
Looks like this one...
Drops me down to 9.98 CR due to 72cc heads.
That's not terrible.
Just Fishing
Can't fix stupid
Utah
Oh yeah sorry two kits. 8cc pistons then 20cc pistons. I have the 20cc pistons. I’m supercharged. With my heads and gasket I’m at like 9.3
:hmmm2:
I have reading to do.
+ i was not happy with one of my rod bushings anyways...
Pistons were sketchy, i expected made in USA, I got Made in india.
"Matched set" = not matched at all.
what's another 2k at this point really...
:yaoface2:
Just Fishing
Can't fix stupid
Utah
Man, that just seems like the AFR heads i have are telling me to do this please.
And my cheap ass pistons are complaining that the AFR heads are calling them lame and other names....
:jester:
That would give me more low end too.
Overkill for what i want, yes.
Or maybe...
:hmmm2:
08z71bgm
Long Island, NY
:hmmm2:
:yaoface2:
Well from the crank rods and pistons. Only the pistons are made in USA. Idk where the crank and rods are but summit don’t put their name on junk. I was happy with the quality when I got them in my hands. Tons of people using hem now days.
Just Fishing
Can't fix stupid
Utah
Forged pistons, i like that very much.
My pistons have some bad reviews...
but it was all i could get at the time.
08z71bgm
Long Island, NY
Forged pistons require coming to temp before use more so than hyperutectic. Forged grows with heat while the others don’t. So you will have rattling and damaged skirts if you don’t let them come to temp before driving.
This is overkill for me and I’m at 700 range. This is insanely overkill for you.
Just Fishing
Can't fix stupid
Utah
Don't know if i will do it or not, but this has me thinking
+ the specs are all there.
I can always copy it in slightly lower quality parts...
briannorris
