DOD FAILED. CAM THOUGHTS
D
decembersend
I haven't placed the order yet but this is the list. Is there anything I'm missing?
TSP L99/L92 VVT Cam Package
SKU:25-L99VVTCamKit
Vehicle: GMC - Yukon - 2010
- TSP L92 VVT-2 Camshaft 220/232 .600/.600 113+6 (25-TSPL92VVT-2)
- TSP .660" Dual Valve Spring Kit w/ Integrated One-Piece Seat & Seal, Titanium Retainers, PAC Springs (199-ISSPACPOL660SpringKit)
- 7.400" (25-7400-1)
- Do Not Include Pushrod Length Checker
- Include Phaser Limiter Kit (4-5456)
- Include VVT Cam Bolt (28-12682000)
- Rollmaster IWIS LS2 Style Performance Timing Chain (11-SR60-2)
- Includes Cam Bolt/Gasket Kit w/ ARP Bolt (28-CamGskKitARP)
- Include TSP Rocker Arm Trunnion Upgrade Kit (25-TSPTrunnionUpgKit)
Texas Speed & Performance DOD / AFM Delete Kit for 5.3/6.0/6.2 Engines
SKU:25-DODdeleteKit
- 16 Chevrolet Performance LS7 Lifters (28-12499225)
- GM MLS 6.0/6.2L (28-12610046)
- ARP Head Bolts (46-134-3610)
- Include L92 Valley Cover w/o PCV Provision for Truck/G8 Applications (28-12598832)
- ARP Crank Bolt (46-234-2503)
- Do Not Need 3-Bolt Conversion Kit or Single Cam Bolt
- Do Not Need - Going With Aftermarket Cam
- Do Not Include Oil Pan Gasket
Headers and Y-pipe are the kooks really worth $1200 more?
Kooks
SKU: 28502400 | 1-7/8" Stainless Headers. 1999-2013 GM 1/2 Ton Truck/2000-2013 SUV.
SKU: 28543100 | 3" SS Non-Catted Y-Pipe. 2007-2008 GM 1500 Series Truck/2007-2010 SUV 6.2L.
OR
Texas Speed
TSP 2007.5-2013 GM Truck/SUV, 2WD & 4WD 1-7/8" Stainless Steel Long Tube Headers #25-TSP1780813TKH​
2010 GMC Yukon TSP 2007.5-2013 GM Truck/SUV 3" Off-Road Y-Pipe - Stainless Steel #25-0813TRKYKit​
Corsa Catback exhaust and CAI
Sport Sound Level (14202) 3.0 IN Cat-Back SSE Twin 4.0 IN Tips 2007-2010 Yukon Denali Escalade 6.2L
PowerCore Filter (44906) Closed Box Air Intake 09-13 Silverado Sierra 09-14 SUV 4.8 5.3 6.0 6.2
hagar
SKU:25-L99VVTCamKit
SKU:25-DODdeleteKit
Kooks
OR
Texas Speed
The kooks are nice, but so are the tsp. If the tsp headers are back in stock, go with them. I personally put new stock gm rockers on over doing the trunion upgrade, they are like 150 bucks for a full set and are used on the zr1 and even the 8 thousand rpm body in white gm performance cars. It's a very split opinion, but I have never in my life had a stock rocker come apart, and I still run them on my 1400 hp truck. I do however put brand new ones on as insurance, that way you get the latest version and freshness.
Other than that, add a dog bone ls2 style chain damper kit and delete your stock chain tensioner, and you look good to go!
D
decembersend
Thank you. I will do that and place the order tonight.
hagar
You are going to absolutely love it! Along with the vvt settings to give your tuner, if he has any issue with the truck pushing against the stock stall, the solution is to killer the power down low by pulling a bunch of timing on coast down. The stock coast down timing tries to run over the converter with this cam because the cam creates so much cylinder pressure down low.
D
decembersend
I'm trying to find stock GM rockers but I can only find them for the exhaust side and can't find them for the intake side.
First I looked on TSP then did a broad google search and now I'm on GMs part side and still no luck lol.
hagar
Pretty common these days. I get mine from tsp, call and ask them if they have any in the morning. The entire supply chain is destroyed right now.
91RS
GA
I would just do the CHE trunnion upgrade on your stock rockers. It is super easy to install with no press or vice needed and then you KNOW it won't fail. It's only $220.
okfoz
You can probably fix your DOD for under $500, and never have it happen again.
D
decembersend
I completely forgot about Rockauto and found the rocker arms on there and placed the order.
D
decembersend
Everything is now ordered and I’m just playing the waiting game now. Thank you to everyone that helped.
I will start a build thread once all parts are on. I plan to get video too and will post links to YouTube
hagar
Yeah buddy!! The most paramount things about doing the job are to get all of the coolant out of the head bolt holes after head removal.. blow them out until nothing comes out, then clean the deck surface of both the head and block with hand power 1000 grit wet/dry sand paper lubed with wd40. Then when everything is spotless, blow the holes out again with compressed air, then clean the head and deck surface up with brake Clean on a non shedding rag. When it comes to the cam install, it is Mega Common to miss on the vvt phasers to camshaft dowel. I will even admit to doing it once because failure is part of life. Try try and try again to make sure the cam phaser is for sure located on the cam dowel while being timed via the indicators like a traditional engine. If you have any questions, just ask!
hagar
Don't use any traditional scraping tools or razors or scroch bright pads on LS blocks or heads, especially the aluminum blocks. The metal head gaskets are a machine gasket finish that requires under 18 micro inches of cylinder surface flaw to seal perfectly. I believe technically 800 grit sand paper is right at 18 micro inches of surface finish, but I always use 1000 grit to be safe. You will find yourself spending an honest 1.5 hours per side between the block and head.. but it is honest work that can only be matched by machining that 70 percent of machine shops can't finish at. Labor of love and such. Lol
hagar
Everyone used to do the comp trunion upgrades as well, and I have heard of so many more comp trunion upgrade failures than stock gm failures. The problem with factory parts failures is that they have millions of examples on the market.. do you think if Che or comp or anyone else had a million sets of ls rocker trunions on the market, they would have less failures than gm?
I think GM has their drag pack car up to like 8200 rpms now, and they still run stock rockers. 7 thousand rpm zr1s running stock rockers. The guy is running a .600 lift cam... I have never in my entire life of like 200 ls3/l92 headed combos with stock rockers, ever seen one come apart.
hagar
I have never actually in my entire life, since starting my career building ls based cars 20 years ago, once ever!! Seen any ls rocker come apart. Not Once!! All the way from back in the days of the magic stick, the crazy .680 lift cam motions that would kiss the pistons.. nothing . Not one. So when I build stuff for my customers, I tell them to go with what has never ever failed me once... not what someone read somewhere will fail them.
91RS
GA
The Comp trunnion kit is crappy and still uses needle bearings. That's why I didn't recommend it and no reputable builder does that I've seen. The Smith Brothers and CHE kits are what is recommended because they use brass bushings which are serviceable. I've never heard of a Smith Bros or CHE failure.
D
decembersend
I've been reading on various ways to clean the heads and block and some have suggest using purple power. What are your thoughts on that?
I will def make sure all holes are cleared, it appears that any little spec can mess up the way the heads sit.
I've been watching several videos from a bunch of different youtubers to learn the best way to do this. Everyone so far has talked about how you want to make sure the dowel is in the 3:00 position and put the sprocket on the dowel as well with the dot in 6 position . I'm just hoping I remember hahahaha. A
D
decembersend
I hope people on the LS1tech forum were joking but some on there stated they use scotch brite pads "I use simple green and my pressure washer, for the surface, i use a scotch bright sponge and simple green, keeping it lubricated while cleaning".
They also say they use 400 grit sandpaper..
I will take my time and do it right the first time. I rely on this truck as my daily so I don't want to mess as thing up.
91RS
GA
I use razor blades and then if I’m still not happy with it I’ll use a red scotch brite and brake clean lightly by HAND. Not one of the discs on a die grinder. I feel like sand paper of any grit would leave way more fine dust behind. I brake clean the crap out of the heads and blow them off/out and shake them to make sure nothing falls out of the coolant passages. The head bolt holes I blow out, then fill with brake clean and blow them out multiple times, then run a thread chaser through all of them, and then fill with brake clean again and blow them out repeatedly until nothing comes out.
johnsonwillie199
