well there all f-in tight I beat on it pretty hard so I'll call it good till next year :burnout:
next up will be taking care of a tiny exhaust leak I think one of the clamps needs adjusting and I am hearing a little rattle around 2k rpm so
I guess I gotta go bug the guys at the muffler shop.
needed to get the brakes all done I have surgery on Wednesday so probably won't be trying to do much for a couple weeks.
Good luck with the surgery, hope it isn’t anything too serious.:)
...I have surgery on Wednesday so probably won't be trying to do much for a couple weeks.
You take care Wes and check in when able to. I'll keep you in my prayers.
They make cheap little adapters. I have one and used a new style can on my old hose, with the adapter.
When did this happen? We just bought a bunch of cans in July and didn't come across this.
pwtr02ss
Tennessee
Walmart, I think. Might have been O'Reilly's. Can't imagine an auto parts store without them.
I got mine at walmart also. They are a POS kinda. Mine felt like the threads weren't going to hold up very well.
I bought a brass one off amazon for the gauges that my buddy Casey owns. I haven't used it yet so I can't give any details on if its a POS or not.
I have a hernia in my lower left abdomen and a 3rd ball o_O both easily addressed, there going to use a poly mesh patch for the abdomen and remove the extra bean, which is really just some kind of fluid/semisolid material (cyst) the doctor is pretty cool he's been doing this stuff forever, the hernia has cropped up in the last year during covid so I am glad most operations are back to normal it's kind of uncomfortable
Just Fishing
Can't fix stupid
Utah
That was my experience with the little plastic adapter.
I hated it so much i spent a few hundred bucks on a case that still had the old style... :jester:
Sam Harris
My a/c started blowing hot hair. I had to go buy freon. I didnt know they had switched out of R-134. Which i guess its more expensive and uses a different hose.
Mine did this recently, and all I had to do was a re-learn. (Granted, this was on my NBS).. might try that first though. Not sure if the procedure is the same, but in the NBS, just pull the HVAC fuse for a minute.. reinsert, then set the key to “on”, and you should hear the doors all moving doing their recalibration.
RooTBeeRthe1st
Got the physical Corn sensor in. Works very nice, and fast, how it should be.
Cheapest GM trying to save 20 bucks when they build cars I guess.
No more garbage virtual sensor for me!
% rising when WOT?
Also, corn went way up, wtf.
St. Louis
% rising when WOT?
Yeah, it's about $2.95/gal here. Was $2.75 a couple weeks ago and in the $2.40s a few weeks before that.
At $2.95 I've been putting in 91 or 93 octane since their prices are about $3.40 and $3.60
% rising when WOT?
I reckon that it doesn't mix 100% and separates when at rest. Gotta do this to all of ours one day.
RooTBeeRthe1st
I had about a 1/4 tank of 91 and put in 6 gals of e85(up to 1/2 tank) pump was insanely slow this morning for some reason.
So that was just after I fired it back up.
It was just nice to see it read that quickly. Whereas the virtual sensor takes a while to change it all, and then it fluctuates up and down a lot. This just gradually moved up and stayed steady.
lowh07
Making plans for new headlights... I'm kinda tired of these u-bar lights. The projectors aren't too good (kind of a V-pattern), they're low beam only and my highs are useless, the HID kit itself isn't good and I've had to replace a few lights and ballasts, and the u-bars have gone out in a few places which looks bad. I've had them for 4 years and for most of that time I've liked them overall. Just ready for a change. The 35% windshield tint didn't help, but that's my own fault :p
I decided I'm not going to try the retrofit myself (buy once cry once?). Too many expensive and/or time consuming things that could go wrong that I'd rather let a pro do. I think I have them spec'd out. OEM style housings painted black/white (zero chrome), quad bixenon projectors, all Morimoto stuff, some other little things
