Caliper brackets, rears should be 122 and front 148 so I went a little over i'm not going to back and loosen them lolWhat are you torqueing to 148 ft lbs back there? I forget.
Eh tight is tight!Caliper brackets, rears should be 122 and front 148 so I went a little over i'm not going to back and loosen them lol
I like stuff tight! so much that I end up breaking things if I am not careful, I especially have to remind myself with plastic that snug is good enough.Eh tight is tight!
I bet you've said that more than onceI like stuff tight! so much that I end up breaking things if I am not careful, I especially have to remind myself with plastic that snug is good enough.
Too tight may not be better. I just rub up on one side and hope the other gets jealous and moves over.I bet you've said that more than once![]()
The fronts are always torqued higher than the rears so if the rears are kinda f-in tight then the fronts need to be f-in tight so I say you’re GTG!Got the front rotors swapped and sway bar lubed, boy those front caliper brackets were f-in tight, tighter than I had the rear ones, couldn't find specs for the Baer but everywhere says 85lbs which doesn't seem right so there back to f-in tight lolView attachment 354932
the bolts are bigger on the front Baer brackets, 22mm -vs-18mm stock, what do the wilwoods torque at?The fronts are always torqued higher than the rears so if the rears are kinda f-in tight then the fronts need to be f-in tight so I say you’re GTG!
Ok, I just looked this up as well as OEM specs. I was wrong, OEM is supposed to be 129 front for brackets to spindle and 148 for rear brackets to backing plate which is backward to me since the front brakes do most of the work.the bolts are bigger on the front Baer brackets, 22mm -vs-18mm stock, what do the wilwoods torque at?
according to these guys it's the other way aroundOk, I just looked this up as well as OEM specs. I was wrong, OEM is supposed to be 129 front for brackets to spindle and 148 for rear brackets to backing plate which is backward to me since the front brakes do most of the work.
The Wilwoods call for to 75 for the brackets, 65 for the nuts (front and rear) that hold the caliper but they’re a different design. The bracket has 2 big ass studs pointing up that the caliper slides down onto and then the 65 lb nuts hold it down. It’s a solid mount that you need to shim in both directions- side to side and up and down so the pads ride perfect on the rotor. There’s no slide pins.
I looked it up on alldatadiy and those guys have it wrong. Here’s both my 08 Silvy and 02 Yukon, both show front of 129 and rear of 148. Well, Silvy only shows the 2500 series rear since the 1500’s had drums. Maybe that was a 2500 series they were working on but that doesn’t make sense, those are 221 front and rear.according to these guys it's the other way around
2007-2013 GM Full-Sized Truck (GMT900) Brake Job
The GMT900 debuted in 2007 and came standard with ABS and stability control. Keep reading for best practices for performing brake jobs on GM's GMT900.www.brakeandfrontend.com
The only thing I know has changed is the valve on the can. The puncture style aren’t sold anymore, so the cheap hose with the puncture plunger is obsolete.My a/c started blowing hot hair. I had to go buy freon. I didnt know they had switched out of R-134. Which i guess its more expensive and uses a different hose.
well there all f-in tight I beat on it pretty hard so I'll call it good till next yearI looked it up on alldatadiy and those guys have it wrong. Here’s both my 08 Silvy and 02 Yukon, both show front of 129 and rear of 148. Well, Silvy only shows the 2500 series rear since the 1500’s had drums. Maybe that was a 2500 series they were working on but that doesn’t make sense, those are 221 front and rear.
Good luck with your surgery, Wes. Hope it goes smoothly, and that you have a quick recovery.well there all f-in tight I beat on it pretty hard so I'll call it good till next year
next up will be taking care of a tiny exhaust leak I think one of the clamps needs adjusting and I am hearing a little rattle around 2k rpm so
I guess I gotta go bug the guys at the muffler shop.
needed to get the brakes all done I have surgery on Wednesday so probably won't be trying to do much for a couple weeks.
I didn't even know they changed the can. Where'd you find that adapter?They make cheap little adapters. I have one and used a new style can on my old hose, with the adapter.
thanks! should be a quick in & outGood luck with your surgery, Wes. Hope it goes smoothly, and that you have a quick recovery.
That's what she said!thanks! should be a quick in & out
