mpg on my 04 5.3 Yukon
Juice17
Hi everyone, I was wondering if 12.9 mpg combined is normal on my Yukon with 150k miles. What can I can check, clean or replace on my Yukon for better gas mileage besides better diving habits. Any help is appreciated. Thanks
Project Denali
Ignition: new spark plugs, coils, and wires (possibly upgraded as well)
Air: new filter/clean and oil if aftermarket KN style, and new PCV valve or if integrated valve cover style, remove and clean, also run some seafoam through the engine running
Fuel: try an injector cleaner of your liking
It is all relative to your rear gearing, your tire and wheel size if not stock, and like mentioned above a tune can always help!
Mudsport96
40.923,-89.488. Illinois
It all depends man. My wife gets 2 mpg less than me with her style of driving than my way of driving. Which boggles my mind because i drive 70 everywhere i go unless in town of course.
Then there are location factors. Is it hilly or flat? High altitude or lowlands. All this plays into the formula.
9C1C
I've gotten as low as 11-12 around town and 16-17 on the highway, generally getting 13-14 most of the time due to combined driving. I have an 04 Yukon 4x4 5.3 with 295/75/16 AT tires.
90% of it is how you drive, just the way it is. I can get 7.5 or 14 DEPENDING on how I drive.
Brake pads can last you 5 years or me 6 months DEPENDING on how I drive
lowering the vehicle and weight reduction can help in addition to how you drive
Imlow78
My 05 z71 with the stock 5.3 I average 16.5mpg and it’s got 192k on it.
Shannon
Sparksalot
Bastrop County, Texas
Driving style and weight carried if maintenance is good. For example both of mine have that engine and same gearing. in thecopcar I get 12.9, but I still have the weapon locker, full of camping gear, an 11 gallon tank of drinking water and a refrigerator. In theothertwin, I get 15-16, but I have none of the extras installed. It’s probably 500-600 pounds lighter. Theothertwin has 185k, thecopcar has 199k.
I often see others with higher mpg, but I probably drive harder.
Mrobinson
Flash1976
Palm Desert Area
Your MPG is pretty normal. I have 2000 4x4 Tahoe, 5.3. Owned it since 40,000 miles, and now have 505,000 miles. I get about 11 - 12 MPG around town, and 15-17 MPG on long open road drives. The mileage is only 1 MPG less than when I first got the rig. No engine work to date.
M123
Viking
Sweden
I do get 19.5 mpg (12 liter/100km mixed driving.
I run stock air filter, pure synthetic oil and our 98 octane With 5% Ethanol in it.
I change my oil very often, use the longer oil filter and yes I know the longer filter the more exposed and less force it can take before it do cave in. I use Wix. What have this with the mpg you maybe think, because the por design of the lifters and pushrod I try stay one step ahead and happy lifters makes a happy engine.
I think the mpg are in the large run are affected by the climate you drive in. Here it's around 300 meters (984,2 ft) above the sea (+/- 100m), dry and cold.
bigdog9191999
sw michigan
wondering if there has been any change as it has been a little while. there are several things that folks dont think of that can add up to some mileage differences. things as simple as tire tread choice and pressure.
WITCH1975
