Replacement motor questions but hopefully fixable
rockdogz
So I seem to have a blown (and not blown as in supercharger) up 5.3 in my 2008 Tahoe. It just happened but I think it’s a spun rod. I had been planning to research engine swaps but this came at a bad time so I just want to swap in a remanufactured engine.
should I go for another 5.3 or is there a straightforward swap or kit for something larger (6.0?) or newer? I need something that’s already sorted out and will be smog legal in CA.
Any and all suggestions on someplace that could hook me up would be most appreciated!
Thanks
Tom
S33k3r
Dallas, Texas
Stick with another 5.3 if you are a Californian. Also, knowing your budget might be helpful but, ultimately, look for a used 5.3 with 100k or less miles on it. These typically go for around $2-$3k around here, and then you have to pull the old engine and install the new engine. You may have to reuse your accessories, too.
rockdogz
rockdogz
Thanks for the info.
I pulled a P0304 code of a misfire and am going to try new plugs, wires, and coil to see if it goes away…may not be a rod after all.
Thanks
Tom
If you look for another 5.3, the 2010 and later engines have VVT. You can opt not to hook this up or pin your wire harness computer connector for it.
Hopefully that code has an easy fix, if not, it may only be time to replace the lifters, VLOM and lifter trays and such.
rockdogz
rockdogz
Thanks, I'm looking into the VLOM now. I have had an oil leak from the top end somewhere and now coolant leak too so would not be surprised to find the intake loose as others have. So we'll see if it's an ignition issue or perhaps lifter.
1BADI5
DMV
Could also be an injector, you'd have to pull your long term and short term fuel trims to verify though.
Could be a burnt valve, bad lifter or valve spring too. At least you have it narrowed down to cyl 4
rockdogz
rockdogz
Thanks I've been wondering about the injectors...how do you get them checked/cleaned? Do I just find a shop that does this?
drdave81
Waterford, MI
Reading into this a bit, what made you think you had spun bearings, and then went to a misfire? Is there a knocking sound?
Not to sound rude, but you seem to be all over the place with this. Spun bearings, ignition issue, fuel issue..............
Before you go throwing parts at it, do you have any kind of a scan tool?
Let's start with some good diagnosis and go from there. It'll save you money. You have a P0304, misfire on cylinder 4. You can take a plug wire from say cylinder 5 and swap them. It's the easiest thing to start with. See if the misfire moves. If not, go to the coil, swap them. If not, swap the spark plug. These are all easy, free tests.
rockdogz
rockdogz
It sounded like a knock at first so I assumed the worst. After getting it back home and hooking up the scan tool, I pulled the P0304 and started researching it. I pulled the plug on 4 and while trying to get the wire off it pulled apart.
While I’m waiting for new wires to arrive I’m going to do a compression check to rule out a bad valve or lifter.
As far as the VLOM, I had already been experiencing some oil leaking from somewhere higher on the block and I was going to replace the valve cover gaskets. I also have some small amount of coolant leaking somewhere although I don’t see it on the ground. I just need to add more to the reservoir monthly when it gets low. When I read about the VLOM issues of oil/coolant leaking I have a feeling it could be related.
rockdogz
rockdogz
Compression checked out ok. Tried new plug wire and spark plug, and swapped coils with cylinder 2 - the misfire stayed on cylinder 4. I suppose it could still be a lifter right? The compression test wouldn't rule that out because it would fail collapsed right?
Injector harness?
TollKeeper
Brighton, CO
While your down there swapping the injectors around, pull the valve cover off, and check for pushrod movement. This will also give you the oportunity to check for the lifter bridge being pulled from the head, or that the pushrod is even under the rocker. I have seen both, but usually on a high HP LS.
rockdogz
rockdogz
Ok thanks for the suggestions, I was going to pull the valve cover next but I will try swapping injectors first. Is there a way to test the injector harness?
I'm not sure but I think you can swap from one side of the engine to the other.
brice715
