Today blower motor #3 went in and is coming out as soon as #4 shows up to the door, sad that we can’t even get a good blower motor for these trucks anymore...2 gm oem’s over heated and sounded like garbage, four seasons went in today and has motor whine pretty bad. Anyone’s curious stay away from gm #1581099 lol
Sounds like you’re getting counterfeits.
Buying off Amazon?
TheAutumnWind
Interesting. Shouldnt be that hard to get a blower motor right.
Buying from Amazon themselves is fine, just not from the 3rd party sellers on Amazon. They're like the EBay scammers.
That's what I meant. Sorry I didn't explain better.
I didn't get an after pic. I cleaned off the grease on the boots, and I installed the new abs sensor. Now I'm getting an abs code for the ps! I bedded in the new brakes. Stops amazing now! Now I just need to get motivated enough to swap out the ps abs sensor.
What was in the hole before?
Just a regular power port. I have a wire coming off that convenience center near the parking brake pedal. I never tested how many volts it is. I didn't tie it into the power port wires because I didn't want the led light to be lit 24/7.
Bigkevschopshop
Northside H-Town
Put it on a relay drawing it main power from the original charge wire and use the keyed power for the switch.
THe old power port you removed -- did it say on the lid what the current limit was for the socket? I'd bet that your new device doesn't pull all that much power at 12v. Got a spec for the USB thing, or a link?
blueinkd
Noticed some moisture on driver side of rad. All hoses are new so I'm thinking the rad gave out. Got this for it's replacement today and a new ambient air temp sensor as well. Going to install it Saturday morning
Mountain Rambler
