4 Piston Big Brake Upgrade from 2019-20
SRQYukon
Sarasota, FL
Why not? Should be waterpoof. I clean my phones with alcohol. Whats the difference?
Seriously? Maybe that was a joke. Why don't you clean your phone with BrakeKleen and get back to us? No, wait, just kidding. It will probably melt it.
TheAutumnWind
I was just kidding too... but man your response seemed very much like I struck a nerve. Not my intent... however challenge accepted!!! Posting from this (now very clean) device
Edit for those coming along later. No nerve struck. Good fun....
SRQYukon
Sarasota, FL
Sweet! No nerve struck, just in jest. I can't believe you did that! Wish I had the **** to try that with my $1100 phone. Wondering if it kills the Delta variant? Who needs hand sanitizer or microban when we've got this?
91RS
GA
Dantheman1540 ....I sent the caliper to tRidiot , that's the last time it surfaced.
I'd like to do the 2 piston rears. Gonna need them.The 2021 calipers etc are here waiting to be installed so might as well do the 2 piston rears while in there. Wilwood brakes was the first choice but the extra money went to Whipple (also waiting install) Whipple was supposed to take 6-8 weeks and that would give me time to do the brakes first. Help me put together a rear 2 piston set up ?
There are a few people in this thread that said the NBS 2 piston rear will go right on an NNBS with just rotors, pads, and calipers. My concern was the parking brake but based on a quick look on Rock Auto, it looks like the parking brake shoes are the same just the retainers are different (which gives them different part numbers if the retainers are included with the shoes).
Fjs0001
Here lately my 05 Escalade has felt slower during acceleration. It also pulls to one side during braking. Two weeks ago I was driving down the interstate and the whole car started shaking. I pulled over to check, but I didn't find anything. I got back in and the problem was gone. Yesterday I noticed that my brakes were sticking after coming to a stop. I got home and I could smell my brakes. Smoke was coming out of my drivers wheel well. Today I found this thread as luck would have it and now I'm going to upgrade to these new brakes. Currently I have the stock 17" wheels, but I have a set of 2010 Escalade 22" wheels that I hope will clear these bigger calipers.
the_tool_man
Upstate South Carolina
Definitely report back on fitment. I'd have the same setup, and want verification that they'd fit before buying parts.
corvette744
2004 Z-71
Northern illinois
ks03
Fool Excess Member
I'm gonna check tonight and see if a NBS 2 piston front caliper will bolt up to the rear. If it does I'll order a 13.5 NNBS rear rotor and a 4 piston test caliper and see if my theory on putting the T1 4pistons in the rear is possible.
The bracket mounting holes look a lot closer together on the rears
Front
rear
fasteddy
fasteddy
That would be awesome!
Good luck with test fit.
I think I backed off on that because of the rear rotor clearance.
But all is possible.
Pretty sure they’re not even close but that’s going from memory and I’m old af. :emotions33:
Dantheman1540
Sugar Loaf Mountain
FrontView attachment 344953
rearView attachment 344954
Totally right those pics are awesome @ks03. Nowhere near close which is kinda expected but knowing H2s used NBS front calipers in the rear I thought there was a chance. Now I need to look at H2 rear brake mounting plates. I have a buddy with an H2 axle in his Tahoe so hes gonna get some pics sometime for me, I'll do some googling tomorrow at work as well.
If it's as easy as swapping brake backing plates I would be okay with that. Pulling axles shafts suck but it's a good time to do out wheel bearings.
Dantheman1540
Sugar Loaf Mountain
More stuff I've come up with since it's bugging me. The H2 rear calipers and NBS fronts are the same part number (Sorta already knew this but part number confirmation is nice) as are their mounting brackets which are separate removable pieces on those 2pots. There for the only thing that could make the difference between H2 rear and NBS rear mounting is the bracket mounting plate on the axle and I confirmed it with Gmpartsdirect.
So the H2 plates are discontinued by GM but it looks like Summit still has some and they may be interchangeable with 3/4ton vans and some NBS HD trucks. I'll order a set and see if they will mount to the axle, might go pick up a NBS Tahoe 10bolt at the scrap yard for testing. Since I just resealed my 14b and don't want to do testing like this on the daily.
corvette744
2004 Z-71
Northern illinois
IF i remember correctly the h2 is a 3/4 ton truck frame chassis and drivetrain and just drop the hummer body on it.
Dantheman1540
Sugar Loaf Mountain
Yes and no, the rear axle is not a full floater like the HD trucks had. It's a 9.5sf 14bolt much like the AXN models from NNBS 6.2 2wd suvs and also found sometimes in 05-06 Escalade 6.0 2wd SUVs. The difference between the AXN and H2 (IIRC) is the outer shafts are not necked down as much leaving larger outer wheel bearings and 8 lug thug shafts. They are very similar to the late 90s HD 1/2ton axles just 8 lug instead of 6.
Being they they share a lot in common with the AXN then they are also very similar to the 10bolts and looking at the backer plate pictures it sure looks like it might work. If not then at least i have a backer plate to take measurements off of and make a custom bracket.
91RS
GA
The H2 is basically a 2500 non-HD or 1500 HD.
varminpoolteam
