2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
It really is getting annoying, I think I'll try reinstalling the new actuator again and check some fuses maybe there's another solenoid or something that I'm unaware of.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I didnt realize the cable running to the hatch handle I broke the clip off of 2 years ago is the same cable that helps align the lock mechanism. Once again that was the problem and it has been solved with zip ties. Being stupid is tough
I was initially planning to target drone around the 2k rpm range but, it seems like it's more offensive lower than that around the 1200-1700 range and actually clear up a tad closer to 2k then gets bad again over 2,200. So I even dabbled in the idea of making 2 one short one long.
What formula did you use I've seen a few different ideas floating around.
Narrow down what RPM the offending noises are worst at and use those in the formula. They'll be the target/center. Surrounding frequencies above and below the center will be affected as well, though.
If you wanna geek out, this is a great video that explains the science as well as the formula:
If @Sam Harris can do it, then surely you can.
Sam Harris
Truth!
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Uhg not that video again! I remember seeing that goober looking dude before, I will watch that tomorrow and take notes because I see graphs and science that's above my comprehension at this moment.
Lol
In school, I was all about science but never was into math. I'm still not into math, but once I'm actually into it due to the context, I find it to be fun and rewarding. I was actually a little bummed that I didn't have any exhaust notes to fix after doing mine! I had to nerd out vicariously through Sam.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Lol
So let me ask you this if someone straight piped their truck and decided to just make multiple J tubes of different lengths would it be tame enough to drive or does it only effect the drone persay?
HeavyHoe03
