Locked out
Ventura139
Hey all. I’m in desperate need for advice. Long story short I was loading some lumber into the back of my 01 Yukon Denali and one of the stick slid down my passenger seat and hit the lock button as I closed the back window. I have an avital 7345L alarm system and when I hit the unlock button it won’t unlock the doors. I’m able to use the remote start so the remote functions but not the locks. I had 2 locksmiths try to open it with no success. The actual door lock cylinders won’t engage and when they hit the unlock button with the jim you can hear it “function” but nothing physically unlocks. Nothing at all. I’m all out of ideas other than picking a window and breaking it. It seems like the alarm system on the truck killed the locks.
Any ideas on what to do ?????
St. Louis
I think the latch for the rear glass can be released rather easily, altho I don't know how to do it, but I remember it being discussed in the past.
Cbncanada
On my 2006 the drivers door will actually unlock with the key. Don't need the remote for that. It is a physical unlock of the door.
thompsoj22
The vehicle thinks you are inside it, Simply get a piece of stiff coat hanger wire and gently pry the driver side door at the top open just enough to slide the wire down and press unlock on the door armrest. I think a good thief could do this in less than 30 seconds!
Jimmyy
Minnesota
That was my thought. I need to use my key when it gets cold out to get the drivers door to unlock.
so 2 locksmiths didn't combined brains to get it open? there are 4 doors, they can't possibly be all 4 broken.
did they use the air bag/wedge method? this forces the door to have a gap at the outermost edge and opens it enough to reach inside with a tool and physically push the lock mechanism open.
ks03
Fool Excess Member
The locksmiths need a z tool, it’s a glorified coat hanger with 2 90 deg bends. They need to reach down along the window and manipulate the lock rod. The finding the right spot is almost impossible without the book on doing it or being very familiar with doing them, the gmt800 is one of the more difficult vehicles for non destructive entry
V
Ventura139
That’s the thing. They were both able to push the unlock button and we both heard the locks actuate but none of the door actually unlocked
I don't think you are grasping what I am talking about, I am talking about the physical door lock slider, that is connected to the rod inside the door, when you slide it, it unlocks the door unless the connecting rod came off, in which case you would just move to another door. it's not rocket science its just a door lock.
V
Ventura139
Both of them weren’t able to get it done. Kinda sad. But I ordered my own lock out kit and will try it my self tomorrow. They both gave up after about an hour but I’ll try until it gets done.
TollKeeper
Brighton, CO
Easiest to replace? Or cheapest to replace? There can be a big difference there.
On my Esky, for SafeLite to replace the rear hatch glass, is 750 bucks! And the correct glass from local yards, its always broken out!
BadDaddy2003
