George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I replaced the sensor and the screen the first time. The screen clogged up a second time and I didn't put it back in. I had DOD shut off in the tune though. I'm not sure why its there but I'm betting there's a million of them on the road without one.
To me that’s indicative of a sludge problem in the engine when a screen in the pressurized oil gallery is clogging. The more I read about failures in these engines my opinion continues to shift toward dirty oil being the root cause, not DOD per se. I suspec GM set the oil change intervals too long. Of course if there’s a failure beyond the warranty, and they sell a new car, is that really a failure? Or planned obsolescence.
I remember reading somewhere that the screen is meant to protect the sensor from that debris in the oil because it gets into the orifice of the sender and causes it to fail. Nit sure how true that is. I agree that the long OCI could very well be an issue.
pwtr02ss
Tennessee
To me that’s indicative of a sludge problem in the engine when a screen in the pressurized oil gallery is clogging. The more I read about failures in these engines my opinion continues to shift toward dirty oil being the root cause, not DOD per se. I suspect GM set the oil change intervals too long. Of course if there’s a failure beyond the warranty, and they sell a new car, is that really a failure? Or planned obsolescence.
I agree 100%. Mine was sludge from adding additional oil to diagnose an oil pump o-ring failure. I added 2 extra quarts and that broke loose build up from the oil level bing higher than it had for the previous 190k miles.
Bill 1960
Testing the Limits
Exactly. And if there’s debris that large in the oil gallery (after the filter! ) then what’s that doing to the bearings and lifters?
avalonandl
Troy, MICH & Naples, FL
I short cycle my oil changes now. My Denali XL has 162k on it now and basically I plan on doing oil changes at 4-5,000 miles. My theory is the previous owners were more concerned about how the vehicle looked rather than maintained it. It had the OEM plugs in it, at 134k miles, had the Jax car wash sticker on it but very few oil changes on the Carfax. Now i know that many small OC places do not report maintenance so I am sure OC were performed. But I am religious about it now. Always was.
Bill 1960
Testing the Limits
Ditto. I am changing mine on about a 2k interval at present, and it’s coming out dark. I got this vehicle at 60k (but 10k hours so lots of slow speeds or idling) and and I’ve done changes at 60, 62, and 64. If it reaches the point where a 2k drain comes out amber then I’ll start extending it.
My belief is factory OCI will build deposits as contamination exceeds the carrying capacity of the oil in the latter part of the cycle. Short OCI especially with good detergent oils will reverse that.
St. Louis
So I'm in the process of changing the sensor out. I can get to it OK, but I can't get the connector off. The side with the safety clip that pulls up and the push retainer is almost facing forward, a bit angled, towards the drivers headlight. It's really hard to get my fat thumbs between it and that damn plastic tower/shield mounted to back of engine. What the hell is that for anyway?
St. Louis
They need to make the socket with a notch up the side like the O2 sensor sockets so I could at least turn it a bit so I can get to the clips
How about using a pick?
St. Louis
Yes. That black plastic cover on the back is pretty flimsy and has like sound deadening foam on the inside. I think it's only there for noise reduction inside the cabin 20210629_135523.jpg
Just Fishing
Can't fix stupid
Utah
Same issue i had when i did it with the intake on.
It's a silly lock.
You need to slide the plastic (grey) piece up in order to get access to the little lock/latch.
I used a small screw driver or a pick to get that fker up.
even easier if you get it all the way out.
Biggest pita about the whole job is that stupid lock.
St. Louis
It's a silly lock.
So once the grey part is up or off what needs to be done to remove the connector? Do you have to press that black split tab part in?
Just Fishing
Can't fix stupid
Utah
IIRC there is a little thing to press to remove the connector once the grey thing is up and out of the way.
I do have my intake off right now, i'll try and go through the process to refresh my memory...
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yes. That black plastic cover on the back is pretty flimsy and has like sound deadening foam on the inside. I think it's only there for noise reduction inside the cabinView attachment 343391
I took that ******* plastic cover off and left it off when I did my valley pan gasket shit.
curbud
