Keeping coolant and transmission temps under control when towing in the summer heat
Geotrash
Geotrash
Dave
Richmond, VA
This was driving around in the city yesterday. This is still like 40 degrees cooler than last year when I had the stock setup.
Minus the dangling cooler tube, this is my setup. I have the big Mishimoto radiator too. The one difference with my new setup is my engine cooling fans run on hi a LOT more, which I don't mind. I have dual batteries and K5L fans, the voltage stays at 14V all the time. I'm keeping my fingers crossed I won't run in to any hot issues.
Yeah, those are quite typical numbers for the Tru cool. It’s a great cooler. I still have the one I removed to install the Derale, and if my mods in the last few weeks don’t solve my transmission temperature problem on tomorrow‘s trip, the Derale is coming out and the Tru cool is going back in, mounted below the lower grille where the Derale currently is.
Geotrash
Geotrash
Dave
Richmond, VA
I made a 500 mile trip on Sunday, I have the tru-cool mounted in front of the radiator as pictured above, since my transmission was rebuilt with extra clutches and etc, it seems to run a bit warmer than it used to, at 7-8000ft elevation and 90deg's ambient, ac going and moving at about 75-80mph transmission heated up to 193, that was not the issue, the issue is this made the coolant heat up to 230deg. turning the ac off seemed to help a smidge and coolant temps were then up and down to around 220-225, so I am planning on moving the tru-cool down to the bottom grill and doing like others have and opening up the lower grill holes, just have to figure out some kind of mount. not sure how much air flow it will get at that lower grill or if will effect any other cooling I am thinking probably not because the lower part is below the center of the bumper cover that should be splitting the air 50/50? up/down
I think that will be the golden ticket. For mounting, you could use the same trick I used (borrowed from @thompsoj22) to mount my Derale to the back side of the bumper - just a couple of small door hinges attached to the steel bumper with self drilling screws, and some steel strap to hold it in position from the bottom. If I put the Tru cool back in, that’s the way I’ll go.
Geotrash
Geotrash
Dave
Richmond, VA
I wonder if the grill opening between the Yukon and Tahoe cause some of this air flow issue. I was above Estes Park the other day with outside temps in the 80's and my trans saw 180 with very aggressive driving up the mountain, and the engine temp never budged off the normal straight up on the gauge. I pay close attention to you guys experiences and am trying to duplicate any hot conditions in case I need to move mine. I go MILES off-road here in Colorado and want to be certain I won't overheat.
I never had any problems with coolant temp with my Tru cool installed until I was towing. Then, even on relatively flat ground the coolant temp would start coming up, but the transmission stayed cool.
Geotrash
Geotrash
Dave
Richmond, VA
Sweet man. I am looking forward to hearing about your trip. Not much has changed here. I did fill back up with 91 with 10% ethanol and now I don’t see smoke. I had to remind myself that the ethanol was added to help vehicle burn cleaner and since the last tank was non ethanol and I don’t have any cats, then any time I feed fuel to the motor it’s gunna dirty burn and there’s nothing to make it clean. Either way if I have to rebuild it then I have to rebuild it. I also may start the process of getting a duraburb from duramax specialties.
Funny you should mention that. Called Duramax Specialties last week and they’ll do it in 6 weeks for $45K out the door. I‘m still mulling it over.
kbuskill
NE. FL.
I thought the Duraburb conversion was done on 2500s exclusively?
Geotrash
Geotrash
Dave
Richmond, VA
No sir. As 03_GMC alludes to, they take your truck's body and drop it on a low mileage Duramax 2500 truck chassis. They also switch out the front clip with a truck front clip to provide the clearance for the engine under the hood and the space for the radiator, coolers and such, do the paintwork, etc. And then they do all of the integration work with the ECU so it's totally seamless.
Geotrash
Geotrash
Dave
Richmond, VA
Well all, I think my cooling issues are resolved when towing. We made the same trip over the blue ridge mountains I made a few weeks ago, and the transmission temp topped out at 232º yesterday at the top of the pass. Last time was before I plumbed the radiator's cooler back into the system and it hit 263, so this is a 30º improvement. Coolant temp topped out around 215, all at 80ºF ambient. Rolling on the highway I was steady between 190 and 196 depending on the terrain. Gonna keep the Derale. set up this way it's the perfect solution, in my opinion.
kbuskill
NE. FL.
It would be interesting to know how much of a difference the new baffles on either side of the radiator made.
Geotrash
Geotrash
Dave
Richmond, VA
Hard to say since I changed 2 things at once. But, I did notice that on the highway my temp gauge never got out of the center spot, when it used to get between 1/2 and 3/4 before I fixed the baffles. I didn’t have the OBD2 dongle hooked up, so I don’t know the precise coolant temps from this trip. But it seems that routing the transmission fluid through the radiator’s cooler hasn’t had any negative effect on coolant temp.
Geotrash
Geotrash
Dave
Richmond, VA
Small update here. Drove back over the mountain today on the way home but today it was 90° outside. Strangely, the transmission ran even cooler today, topping out at 226°F on the steep eastbound climb. The coolant temperature spiked briefly at about 230°, and then shot right back down as the fans kicked in, staying around 217° for the remainder of the climb. On the highway, I never saw above 210° for coolant temperature, and the transmission stayed around 190°. So, it seems that the new baffles have dropped the coolant temperature between 5 and 7°, all else remaining equal.
thompsoj22
Im coming in late on this conversation, My baffles are toast also and id like to simply replace with oem, Did you replace/repair/manufacture your replacements?
thompsoj22
I would not have thought that running the DERALE as a stand alone without the radiator in the circuit would have decreased its ability to control the trans temp? I stll have the radiator loop in my setup and felt i should have eliminated it. Maybe i should just leave it alone, I have been known to fix chit til it breaks!
Geotrash
Geotrash
Dave
Richmond, VA
Me either, but that’s definitely what my data shows - by a significant margin of 30-40°F on the same mountain climb, with similar ambient temps, and also 10-15°F on the highway.
On the baffles, I made mine from scratch from black coroplast sheet, and used zip ties to hold them in place.
03_GMC
That’s good news brother!! I’ve been MIA due to no cell coverage and spotty internet. First since you saw temps in your trans around 260 before I’d recommend doing a fluid change. Most ATF breakdown over 240.
So I definitely need to do baffles. If I choose to keep this as my tow pig I will also have to upgrade the radiator. We are in Casper WY for the night and today we drove from Grant Campground in Yellowstone to Casper via US26. There was some pretty gnarly climbs between Grant and Riverton. My trans never went above 225 but I still get coolant spikes up to 240ish and then it will cool back down. Also that weird fluid leak happened again on the drivers side. Not as much this time and it’s definitely hydraulic smelling fluid like power steering, brake, or shock. Not too sure what to think about that but oh well. After this trip though I am really considering a Duraburb or an Express van.
Geotrash
Geotrash
Dave
Richmond, VA
Sounds like a Cold Case radiator might be in your future, though 240 is still 25º less than red line. That fluid leak is weird. Seems to happen when you're running it pretty hard.
Glad y'all are having a good trip so far. Yellowstone is pretty spectacular. We'll be traveling 287 from Lander until we pick up 26 into Grand Teton NP, and then again on the way out from Shoshone to Casper. Drove those roads many times back in the day. Goes past a place called Hell's Half Acre west of Casper that was pretty entertaining to look at, as I recall.
I was seriously considering a conversion from Duramax Specialties, but with this thing running so well now, I'm going to keep rolling with it.
03_GMC
Do you by chance have a link to the cold case??
Hodmjstone
