Scottydoggs
Need that in my Hoe!
its worthless on street tires. need some stickys.
but you could always set the limiter to 5k and let it pop and bang in neutral like a 17 year old at a car meet these days lol
I'd do a slow roll then nail it at 40-50. BRING THE THUNDER!!its worthless on street tires. need some stickys.
You can even add a line lock for the front brakes.. I wanna see it in action.! You should install a sequential shifter next... and then, program your WOT shifts to be clutchless.. [emoji16][emoji51][emoji84]oh, your looking for maximum destruction are ya lmao
pro tip, not the intended purpose for getting one. its a launch control.
it can also retard timing and add it back at a delay rate, any where from 0.2 to 3.0 seconds. my thinking is if you got a lot of hp and its spinning off the line you can cut back the timing ad add it back after your launched to keep it from spinning.
Where are y’all finding the Esky headlight knobs...? I must have weak Ebay fu... I can’t find any.
I did mine a year or two ago. @915_Tahoe did you do all 3 sets of AC knobs? It took me awhile to find them all.Just did my esky headlamp knob with matching esky a/c knobs.
Yes I did, but I found only 5 for the upper controls at the local wreckers. Seems like the main unit either uses bigger ones or I may need the Cadillac ac control, cause the knobs are smaller on the main control. So I found the upper roof panel with control, so that finished off my ac knob swap, then found the headlamp switch.I did mine a year or two ago. @915_Tahoe did you do all 3 sets of AC knobs? It took me awhile to find them all.
The things you can do with programming these today is just awesome.
See.. now I have to do these as well, since I started...I did mine a year or two ago. @915_Tahoe did you do all 3 sets of AC knobs? It took me awhile to find them all.
Here’s mine.Yes I did, but I found only 5 for the upper controls at the local wreckers. Seems like the main unit either uses bigger ones or I may need the Cadillac ac control, cause the knobs are smaller on the main control. So I found the upper roof panel with control, so that finished off my ac knob swap, then found the headlamp switch.
I'll post a picture of them, when I get out of work
Go to www.automotivetouchup.com , buy the paint and clear and do it yourself.
You see how the knobs are smaller on the main ac control, not sure if they should be bigger or if i need the Escalade ac control
Mine aren’t like that, they’re bigger.You see how the knobs are smaller on the main ac control, not sure if they should be bigger or if i need the Escalade ac control
Lucky dogMine aren’t like that, they’re bigger.![]()
Yeah, I was thinking these look bigger than the knobs on mine..Mine aren’t like that, they’re bigger.![]()
Yes, just the white lineYeah, I was thinking these look bigger than the knobs on mine..![]()
But they’d likely fit better on the overhead controls.. those look janky. OTOH, do the Esky knobs have a light provision..?
That sux! Got any damage?Replaced the drivers door light at the bottom of the door and then the driver side "LT" marker that fell off. LMC Trucks is my friend. Then got rear ended by a Hyundai!!! He was totalled.
