2005 Crown Victoria P71 Build
95escahoe
95escahoe
So I found some window bars I like, they are slightly different then the ones I was looking for, these ones are no drill you remove the door panel, pull the window weatherstripping install these then put it all back together. They should be here tomorrow so I can most likely put them on Wednesday morning before work.
Sparksalot
Bastrop County, Texas
Those are cool. I'd like to find a set of the door panels to go in mine. I may have to make a set.
95escahoe
95escahoe
So the no drill window bars came yesterday when I was at work I threw them on this morning, install was very easy. Remove the door panel and weatherstripping install the window bars and put it back together, only issue was where the bars go is where the top of the door panel slides in there’s a lip so it wouldn’t sit flush so ended up cutting that lip off and the door panels fit like they did before and come off as easy as they did then and you can’t even notice it was cut.
Instigator01
