Sparksalot
@RooTBeeRthe1stSo.. it’s pretty much expected you include pictures as a general rule. But.. with a post like this ....!?!?
Absolutely MANDATORY...!
Pics, or bannination!!!
I cried about my terrible "piston slap"
My 2003 used to do it often.It's happened to me once with this 2012 last year I did a hard stop and left turn and she bound up on me for a second, only did it that one time that was right around the time I bought the girdle and cracked it open expecting to find some metal bits in there but there was nothing.
my 00 did it sometimes but I beat the hell out of that thing I think I went thru about 4 carriers and finally put a eaton detroit in it and then proceeded to wear the bearings out on that never broke the eaton though.My 2003 used to do it often.
A recalibration might work but usually it doesn't, to do that just pull the hvac fuse wait a few seconds and put it back in then just turn the key to run for 10-15 seconds you should hear the doors moving back and forth. or use a tech2 if you have oneSo my blend door doesn’t want to stay on face vents
I’ll give that a shot. What else would fix it?A recalibration might work but usually it doesn't, to do that just pull the hvac fuse wait a few seconds and put it back in then just turn the key to run for 10-15 seconds you should hear the doors moving back and forth. or use a tech2 if you have one
Doing that now. Seems like it’s working for now. Issue I was having it would go to face on start then 5 mins later it would be on windshield but auto is off and it’s on face only with recirculate and aux.When I replaced my HVAC controls mine acted like an ass too. I disconnected the battery a while and it seemed to reset after turning the key on and waiting like my freind @Doubeleive said. Hope it work for you too.
Make sure to set the temp to about middle and it won’t hurt to touch the positive cable to the negative battery post before reconnecting it, to get rid on any residual. Then don’t touch the controls for a few minutes after starting the engine.Doing that now. Seems like it’s working for now. Issue I was having it would go to face on start then 5 mins later it would be on windshield but auto is off and it’s on face only with recirculate and aux.
I’m paying that for real gas.
Hope you’re not on the freeway doing 30-35 mph!̶ ̶a̶ ̶h̶e̶a̶l̶t̶h̶ ̶s̶u̶g̶a̶r̶ ̶p̶l̶a̶n̶t̶ ̶ ̶ ̶I̶ ̶m̶e̶a̶n̶i̶t̶'̶s̶ ̶$̶4̶.̶1̶9̶ ̶ ̶f̶o̶r̶ ̶p̶r̶e̶m̶i̶u̶m̶ ̶b̶r̶o̶.̶.̶.̶.̶.̶ ̶ ̶i̶f̶ ̶i̶t̶ ̶g̶o̶e̶s̶ ̶a̶b̶o̶v̶e̶ ̶ ̶4̶.̶3̶9̶ ̶i̶'̶l̶l̶ ̶s̶w̶i̶t̶c̶h̶ ̶t̶o̶ ̶r̶e̶g̶u̶l̶a̶r̶ ̶g̶a̶s̶.̶.̶.̶
̶ ̶ ̶I̶ ̶h̶a̶v̶e̶ ̶s̶l̶o̶w̶e̶d̶ ̶d̶o̶w̶n̶ ̶a̶ ̶l̶o̶t̶ ̶t̶o̶ ̶3̶0̶-̶3̶5̶m̶p̶h̶ ̶ ̶t̶h̶a̶t̶ ̶i̶s̶ ̶w̶h̶e̶r̶e̶ ̶i̶ ̶g̶e̶t̶ ̶t̶h̶e̶ ̶b̶e̶s̶t̶ ̶m̶p̶g̶ ̶(̶3̶0̶-̶3̶3̶ ̶m̶p̶g̶ ̶i̶s̶ ̶s̶h̶o̶w̶n̶ ̶o̶n̶ ̶t̶h̶e̶ ̶ ̶D̶I̶C̶ ̶s̶c̶r̶e̶e̶n̶.̶.̶.̶ ̶ ̶t̶h̶a̶t̶ ̶m̶e̶a̶n̶s̶ ̶r̶e̶a̶l̶ ̶l̶i̶f̶e̶ ̶m̶p̶g̶ ̶s̶h̶o̶u̶l̶d̶ ̶b̶u̶m̶p̶e̶d̶ ̶t̶o̶ ̶2̶8̶-̶2̶9̶m̶p̶g̶ ̶i̶s̶h̶ ̶)̶ ̶o̶r̶ ̶.̶1̶5̶¢̶/̶m̶i̶l̶e̶s̶
I don't even pay for my own gas why i do care about the price
he should not plan on turning it off but actually buy the chip...Scotty’s take on GMT900:
High praise especially considering he’s a Toyota lover.
I’ll do that if it stops workingMake sure to set the temp to about middle and it won’t hurt to touch the positive cable to the negative battery post before reconnecting it, to get rid on any residual. Then don’t touch the controls for a few minutes after starting the engine.
Traffic breaks!Hope you’re not on the freeway doing 30-35 mph!
Maybe it doesn't like your face? [emoji848]Doing that now. Seems like it’s working for now. Issue I was having it would go to face on start then 5 mins later it would be on windshield but auto is off and it’s on face only with recirculate and aux.
I̶ ̶m̶e̶a̶n̶ i̶t̶'̶s̶ ̶$̶4̶.̶1̶9̶ ̶ ̶f̶o̶r̶ ̶p̶r̶e̶m̶i̶u̶m̶ ̶b̶r̶o̶.̶.̶.̶.̶.̶ ̶ ̶i̶f̶ ̶i̶t̶ ̶g̶o̶e̶s̶ ̶a̶b̶o̶v̶e̶ ̶ ̶4̶.̶3̶9̶ ̶i̶'̶l̶l̶ ̶s̶w̶i̶t̶c̶h̶ ̶t̶o̶ ̶r̶e̶g̶u̶l̶a̶r̶ ̶g̶a̶s̶.̶.̶.̶
