2004 6.0 NV4500 Tahoe
pwtr02ss
Tennessee
I have a feeling the set I have coming that has the hump completely shaved will fit but, it might be too close for comfort. If I have to run spacers I may get a hub-centric set the 1/4" set I have is about as cheap as it gets.
Keep me posted on that. I'm sure they fit the same on a NNBS so if I redo the brakes on the avalanche, I may as well upgadre.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I certainly will :waytogo:
Also, @randeez I just put the block into a vice and tried to spin the hose inside the block but it did not budge a bit. Not saying your wrong just saying I'm a little biotch:gayflag:.
Here are some up close pictures of the line with the seal it had when it leaked, I see no failure with the seal or any cracks or holes that would allow a leak from there.
randeez
south florida
make sure its tightening down flat on the seal also
trying to describe it... but say where the bolt goes into the compressor. you put the hose on there flat and as you tighten the bolt its not bottomed out where the bolt is, so you tighten up that gap, but it pulls the aluminum block in further on that side, opening up the opposite side. you may need a washer or something to make the bolt tighten up before it pulls the one side in too far
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I gotcha, I definitely take my time tightening the bolts down carefully and by hand, no dugga duggas. What's odd is it's been around 6 or 7 months since it happened last time which I believe was due to me pulling the head and bending the compressor way out of the way. Not sure what happened suddenly to make it leak everything out in a day.
Next time it's going together with a softball-sized glob of JB weld encapsulating the entire area.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
that sucks.... im going to end up redoing the big hoses on mine also it looks like
I've always planned to do that, I have the badass hydraulic crimp tool. I wish they made compressors with AN fittings, I wouldn't mind paying out the ass for expensive high-pressure hose and extra expensive AN fittings. I just feel the single bolt design and o ring is terrible. Although it works on millions and millions of cars and trucks everyday so wtf do I know.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Thanks sweet cheeks
What size rotor is the 2021? IIRC the NNBS is 13" and NBS is 12"? We did that NNBS upgrade on my buddies sss
And good luck on that AC hose. Summer and no cold air sucks
It's already fixed and I returned the supposedly bad hose since it was under warranty. The NNNNBS rotors are 13.5" the main upgrade to that swap should be the 4 pistons.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Went to the alignment gods at DRZA today. The Belltech bushings did the trick and he got the alignment about as perfect as can be. The truck is considerably more stable, safer, and the no longer shots in a random direction when I romp it.
Bad news is my AC went out again. I see no leak and it had plenty of pressure, too much pressure actually. The high side was right around 350 but the low side was pegged at 120! It was about 95*out. I'm vacuuming the system the refilling to see what happens as nearly every component is new and I don't know what else to do.
Heres some random undershoot pics of the trucks. Also i borescoped my cats Monday and sure enough they are real.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Well when I was at the alignment shop I convinced him to help me out with my exhaust debacle. He does some crazy nice exhausts like full titanium with pie cuts and other gorgeous stuff, typically not old Tahoe junk. Anyway, I ordered the big ole Gibson dual 3" inlet single 4" out muffler, a Duramax 4" mandrel-bent tailpipe, and a big ole tip for the ladies ;). Hopefully, this will be the final rendition of the exhaust.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Wasted $28 on this dumb under car washer thingy. It's well made but theres no way to keep it going to direction you want it just spins at the QDs.
Gave it a good spray down with the regular pressure washer anyway and noticed the brake master is getting oddly dirty, it must be leaking from somewhere.
View attachment 278172 View attachment 278173
Don't like that sprayer? I was thinking of getting that one myself. Home Depot?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Amazon, it's a pretty bad design there's no way to control which direction it goes because it's able to swivel at the QD attachments. It's kinda like trying to push a rope, anyone over 40 should understand :jester:
Also, the way my electric pressure washer works it changes pattern with QD nozzles, well it also somehow changes over to soap lessening the pressure with a different QD nozzle and somehow the sprayer attachment did the same. So all I could get out of it was low pressure and bubbles. Good for an initial soak down but I need moar powa baby.
Candielaine
