2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I don't know enough about exhaust brands/sounds to weigh in on this but it looks like you're on the right track. I have magnaflow muffler on my orange truck and their catback on my camaro. Reasoning behind both was, they were quiet....
Yep, quiet is key, I like the sound level it has currently but wouldn't mind just a hair-less drone on the highway. Might look into doing a 3/3-4 Y before the muffler and doing a big ole 4/4 muffler as well but typically the 4/4 mufflers are for diesel and I read they sound like crap on a gas motor.
I found this cool muffler that I think would fit well behind the axle tucked up high and probably knock out some drone.
pwtr02ss
Tennessee
Since the 4th gen fbodies are single 3", a lot of guys run a "bullet" style muffler in between the headers and the muffler to help with drone. At little more compact but you'd have to do two fo them.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I have a wide variety of 3" resonators in stock, Vibrant bullets, Ultra quiets, and Dynomax bullets. The problem is finding room for them, unless I cut out the cats which are some sort of high-flow cat from the PO there's pretty much no space in the Y pipe. Might be able to fit some directly welded to the front of the muffler which would be awesome but they would have to fit between the trans cross member, frame, and floor which is pretty tight and may mean reworking the y pipe.
Last year when I was trying to knock out the drone I tried adding a set of bullet resonators at the tailpipe right before the tips and noticed absolutely no difference so I'm not sure anything small like that is worth trying to fit after the muffler. Which is why I'm interested in that big odd shaped muffler thing.
Another note IDK if those cats are even real or not, I might borescope them to see.
Sam Harris
Do a helmholtz resonator! Then you don’t have to worry (as much) about the room, and you can just cut the drone you have specifically. [emoji16][emoji106] @iamdub talked me into it, and I’m quite pleased with the result..
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I might finally try that, whats kept me from doing one from the start is that they only target a specific rpm right? For example, If I built one to cut out drone at 2,100rpm while on the highway in 5th at 75mph it wouldn't do much if I'm towing and keep it in 4th and 2,650 at 75mph right?
Sam Harris
Yes, it does target a specific rpm. I had the most drone at 2k, cruising on the highway, so that’s what it’s tuned for.
Sam Harris
Its 1" per 100rpm right? so 2,000rpm drone you want a 20" pipe? does it matter the diameter or the pipe?
There’s a little more to it than that. I don’t remember off hand how it was calculated, but it’s pretty simple. Here’s a video of a guy explaining it. Haven’t watched this yet, but seems good from the start anyway. https://duckduckgo.com/?q=how+to+ma...i=https://www.youtube.com/watch?v=z5SY5oUTEcc
After my work meetings I’ll watch. [emoji16][emoji106]
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
There’s a little more to it than that. I don’t remember off hand how it was calculated, but it’s pretty simple. Here’s a video of a guy explaining it. Haven’t watched this yet, but seems good from the start anyway. https://duckduckgo.com/?q=how+to+make+a+helmholtz+resonator&t=iphone&iax=videos&ia=videos&iai=https://www.youtube.com/watch?v=z5SY5oUTEcc
Interesting character there but good info. I found this thread on it I remember reading some years ago. I think I will everything I can to get the clearance needed for the exhaust and get as many of the resonators that I already have in there. Then if it's still droning I will do a J tube.
I could probably do the J tube myself with a kit of 2" tubing bends.
https://www.performancetrucks.net/f...-resonator-tube-eliminate-drone-489463/page6/
It targets a specific sound frequency. You use the RPM that the offending noise happens at as an earmark and run the calcs to determine what frequency it is then build the tube accordingly. If you had a way of knowing the frequency of the offending sound regardless of the RPM, then you could skip a lot of the math and build a tube 1/4 the length of that sound wave.
It targets the center frequency, but there is a rolloff of the surrounding frequencies that are also attenuated. I don't know the rate (slope), but it's not just that one specific frequency and that one only.
Sam Harris
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
When the time comes I'll probably do one off the 4" single tail pipe kinda where the spare tire used to go. I think it could be tucked up there nicely.
Man, Mr. Lahey is gonna be so mad...!
(RIP Mr. Lahey)
There was a maintenance dude pacing back and forth in his golf cart.
R.I.P. Mr. Lahey
Gave the clutch a good workout today dragging the last couple of oak logs into position around my planter. I'm not sure how heavy these are but it takes some serious whoopow to get them moving. The last one really gave me a fight because the position of the back tires was sand and dry leaves, a recipe for no traction. The 420s did their best but it ended up taking multiple clutch dumps and laying a path of boards and pavers to get it out. G80 is truly a champ in these situations, locks right up and starts digging.
Candielaine
