I wish I could score the '21 PPV brakes.
I ordered the standard '21 Tahoe front calipers. They're a fixed 4 piston caliper, they got a ****** shit ton more clamping power by design.
I still need to get pads and rotors....but those are easy to get. The calipers have been on a national back order and are still hard to get now.
The ‘21’s bolt right onto the NNBS? Need brackets I assume.
Nope bolt right in with a single washer. They're a fixed caliper, so no bracket.
The caliper bolts to a bracket that’s attached to the knuckle in the front or backing plate in the rear. So these bolt right to the NNBS brackets? I know when I upgraded my NBS fronts to NNBS calipers and the larger rotors I needed to buy the corresponding brackets. Some calipers come with them included, some don’t. When I look up the part numbers you ordered I don’t see them included.
1BADI5
DMV
There is no bracket, its a fixed caliper that bolts directly to the spindle/knuckle.
Just Fishing
Can't fix stupid
Utah
oooooo
do want.
how hard is the conversion?
and my hoe is supposed to have the "upgraded brakes"
i have never looked too far into it, the most i did was to totally flush my brake system.
Just Fishing
Can't fix stupid
Utah
First rod and piston i separated, i sorta gouged the bushing in the rod :eek:
Thinking i was fkd on that rod, i did some searching and found the bushings are available...
https://www.summitracing.com/parts/slp-4514y
any experience having bushings installed?
I was sorta thinking i might as well have all 8 freshened up while i was at it.
CHOO CHOO
BackPagePhil
Manheim, Pa
Pics..? STFU.
Pics of me dropping them off? They still at the shop foo.
Maybe this will help wet your whistle [emoji6]
Sent from my Pixel 3 using Tapatalk
Bill 1960
Testing the Limits
Spent parts of the day flushing out and refilling the cooling system with some fresh Deathcool. I can tell someone has worked on it before and threw out all the factory spring clamps. :mad:
It’s been presenting no problem, I just want a fresh baseline with all new fluids.
Just Fishing
Can't fix stupid
Utah
i ordered a new ac compressor, some vac pump oil.
And a new AC flush tool since i took my old one and made it into an LS engine oil primer...
new one says 1000ml, whatever that means.
silly metric or whatevs.
CKendrick
