AlejandroDinero
Destin
This is about to go down in a minute..
So, I couldn't leave well enough alone and I picked up some Chemical Guys Lightning Fast Carpet and Upholstery Stain Extractor to try to work out some of the spots that were left after the car wash guys steam cleaned the interior. So far it's lifted every spot I've used it on! I'm super impressed with this product and wanted to share my success with y'all in case anyone was looking for a good spot cleaner.
Might want to let your car wash detail guys know about it. They may be stuck with a certain brand of product but it might be an option for them to use.
blueinkd
What brand are these?? I still got a little soft spot for 3" spindle lift on mine. Getting rear main seal done tomorrow and then maybe around summer time
I have some of that. I tried it on some spots in my headliner, worked fairly good iirc.
AlejandroDinero
Destin
LAFORMO Silverado Sierra 3" Lift Spindles Knuckles Replacement for 2WD GM 1500 Truck SUV Chevy Silverado Sierra 1999 2000 2001 2002 2003 2004 2005 2006 2007 Lift Spindles Knuckles Suspension Level Kit https://www.amazon.com/dp/B08P2K4BV...abc_AX2VXSBJEFZDX5XA46MY?_encoding=UTF8&psc=1
That’s who I went with, I was I’m gonna do mine Tonight but decided to wait in to finish my gauges and do everything tomorrow
What gauges are you doing? Aftermarket?
Never heard of that brand. You trust them?
NoReverseYukon
NE Wisconsin
Finally determined what is causing the belt squeaking. The damned power steering pump pulley needs to be adjusted out approx. 3/16". This was a new one for me - never had one move before. Tool to do the job arrives tomorrow. If it had to move it in, I could have just used a 3/8"-16 bolt, nut and washer. But at least the threads are in good shape for a solid bite.
3/16" is a bit much, but I've aligned them with washers behind the accessory bracket. I don't know if they were deformed brackets or what.
ks03
Fool Excess Member
I don’t know about you but I’m not putting either one of those brands in a place that requires removing the transmission in order to replace.
But if you had to trust one... rear main or steering knuckle?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
@Tonyrodz
Sorry to bother so much, but what is the height on the front of yours from ground to fender lip. I have my appointment for the alignment at 2 but need to get this done before it. If I were to max out the keys on lift would that make the truck leveled with the rear
@Tonyrodz
I know it's in my build thread, but I don't have time to check it. Omw to the dr's and I'm starting to run late. I THINK the front is somewhere around 32"--but not positive, sorry. If you crank the keys up--I actually did it too--it'll bring the front up where you want it to be.
915_Tahoe
HELL PASO, TX
Thank you, ill check you thread and good luck at the doctor's
wwiizz
