Air Bag recall
Caligirl
California
Sorry, clueless here again haha...is anything affected in the ECM when work done on airbags? Going to send our ECM to LT1swap to get AFM deleted ASAP and their website says: "GM Sometimes has new software for your vehicle, including some recalls for emissions. If you take your vehicle in for a recall that involves reprogramming the ECM, they will overwrite the AFM Delete programming I do."
Is airbag recall work purely mechanical and involve any "reset" on the ECM?
wsteele
A day late, I could have asked when they replaced my AB on Thursday. Sorry.
It has nothing to do with the ECM. You’re good.
vcode
I have pulled mine out a couple times when I swapped my interior including the dash to an LTZ. You just drop the glovebox door down by pushing in on the tab on the right. That lets you remove the (2) 10 mm bolts that secure the airbag, and then you reach up with your fingers to the underside of the dash to release the tabs around the perimeter of the airbag cover one by one as you push up on the airbag module and it comes out the top. The cover gets switched onto the new airbag, then you put the assembly into the dash and slightly push down as it snaps into the dash, then install the bolts. And of course unplug and re plug the wire harness.
Interesting, thanks. My local dealer said any trade-in's with an open airbag recall are going straight to auction......
kbuskill
NE. FL.
I haven't received a notice/letter in the mail but when I go to the site it shows parts available.
I called the dealer I bought the truck from the other day and they said no remedy available yet.
I called the dealer closer to my house today and they said they have parts and I can schedule to have it done next week.
They also told me they aren't responsible for anything that happens to the dash and they won't be replacing it if it cracks.
Mine has one small crack at the left top corner of the passenger airbag cover.
I asked if they can do it from below or if it must be changed from up top, he said it depends on the dash. I assume he means LTZ or non LTZ dash.
I have heard conflicting reports as well as to how it comes out.
I know that the inflator is the actual problem but I am not sure if the whole air bag gets changed or if the inflator is a separate part that can be changed.
If it is just the inflator then I have read that it can be swapped from below without removing the airbag cover from up top.
I am hesitant to leave my truck at the dealership. I don't trust anyone to work on my vehicles without my supervision.
My Silverado started with an LT interior. I swapped it out to an LTZ interior including the entire dash and dash sub assembly. The airbag was interchangeable although I don’t remember if the cover was. I swapped the cover from the donor vehicle onto my airbag but iirc it was because I was concerned about an exact color match. And also of note- the LTZ dash I installed was from a Tahoe, and they both come out from the top. I also pulled the airbag at least once when the dash was an LT and was cracked right there by it and had no issue with cracking it more. IMO you have less chance of cracking the dash if you pull it all the way out because regardless of if you replace just the inflator or the entire airbag, I’m almost 100% sure you have to pull the 10mm bolts that hold it in and once you do that it’s still attached to the dash so if you start moving it around that’s when you’ll crack the dash. I held mine from underneath and unsnapped the cover, lifting the whole thing out from the top.
Edit: if it was me, I would pull the assembly out to work on it, it’s much easier than it would be to try to work on it from underneath but who knows how they do it.
Millennium Falcon
CA unfortunately
My parents and I got our letters last week. I called the dealer from whom they bought their Yukon yesterday to get an appointment set up, and they said they would call back when they checked availability on the bags. They called me back today, and we set up an appointment for tomorrow to get both vehicles done. Evidently, they actually have the parts on hand now. Hopefully, both vehicles get done tomorrow.
I had mine replaced about 2 weeks ago at my work (chevy dealer) it was pretty fast and easy to just do the passenger side bag.
@Drok did you wait or did you have to leave it for a half day or whatever. My appointment is tomorrow at 8am and I’m wondering if I’m gonna need a ride home and back.
i work at the dealer so i waited haha. It was maybe a 20 min job
I do know how long it takes, I’ve pulled mine 3 times. So I finally got through to the service department and asked if I could wait since it’s a quick job. The guys starts out with “well, we only have 3 techs but once we start, it takes about an hour and a half”. I told him maybe more like twenty minutes, I’ve done it 3 times on this truck. He started to stutter and stammer so I just said “ok, whatever”. Then he said they’ll give me a ride home and come pick me up when it’s done so I said cool, see ya in the morning.
Nothing like an educated consumer to catch them off guard.
Got it done today. They called a Lyft for me both ways, home and back. Also had another open recall on emissions so I said go ahead, didn’t want an open recall. They had to flash the ecm for that one. Didn’t say anything about the tune but I’m pretty sure the tune got erased, I noticed the cam lope isn’t there so I’ll reinstall it with the Autocal. It took 2 1/2 hours and no damage was done to the dash. Glad to get that done.:)
Millennium Falcon
CA unfortunately
I got mine and my parents' Yukons done this afternoon. Mine took just under an hour to do, but my parents' took nearly the full 1 1/2 hours. No cracks in my parents' dash, and no new cracks in mine, so I guess everything went okay.
StevenFromTexas
Mr. Negative
Lubbock, TX
Called a Chevrolet dealer (Scoggin-Dickey in Lubbock, Texas) today and was told by a service writer that I would have to leave my 2010 Chevy Tahoe "for a couple of days" and they would have to "R&R the dash". I assume "R&R the dash" means "Rip-out & Reinstall the newly cracked dash" or something like that. Told the service writer "No thanks!" and that I wouldn't be getting the recall work done.
They’re idiots. Call a different dealer. The dash isn’t even really touched. I have replaced my airbag 3 times, it takes 15 minutes. It comes out the top, easy. My dealer performed the recall in 3 hours which I’m sure included my truck waiting for 2 1/2 hours in the parking lot. They provided transportation to my home and back.
bayareadude84
Methahoma(temporary)
Sounds like there trying to "Milk" out GM $$$ on labor
Dave
My dealership is knocking them out in 30 minutes or less.
Im sure most are but they still want the vehicles for a couple hours or more. But any dealer that says they need the truck for 2 damn days and they need to “r&r the dash” like @StevenFromTexas has heard is being taken for a ride. Makes me wonder exactly what they’re trying to pull, maybe sell parts and labor on things they “find” while they have his truck.
BadDaddy2003
