Cabin Air Filter Retrofit
kbuskill
NE. FL.
Has anyone used this kit? I am very curious as the effects it would have on the HVAC System. I would love to have the filter but was wondering if anyone had done this before or could speak on it.
Dorman 259-200 Cabin Air Filter Retrofit Kit for Select Cadillac / Chevrolet / GMC Models https://www.amazon.com/dp/B00NF1TL1...abc_CXA2HEKMQ68J7NQ4PEFC?_encoding=UTF8&psc=1
I didn't buy that exact kit. I bought the AC Delco retrofit door by itself and then bought a good activated charcoal and baking soda filter.
My truck had 260K+ miles on it when we did it and the evaporator was disgustingly nasty.
The A/C will freeze you out of there now.
Here is a link to the post in my build thread that has the pics from the install...
https://www.tahoeyukonforum.com/thr...rb-ltz-mod-thread.100141/page-75#post-1512100
TheBiznisKitty
TheBiznisKitty
Do you know what size air filter it was or are they all the same size? I thought about buying the K&N cabin air filter
TheBiznisKitty
TheBiznisKitty
I put one in thecopcar a few months ago. Cutting the opening was the hardest part. The rest was easy, and it works.
Did you clean your evaporator/condenser while you were in it? Did you use the liquid cleaner or what did you do?
Sparksalot
Bastrop County, Texas
It was actually pretty clean for being 10 years old. I brushed a few leaves out, and that was it.
I probably ought to do this on theothertwin as well. I SURE that one will be loaded with dog hair.
I bought my retrofit kit from Rock Auto, and I also use the activated charcoal filter. I've had no issues with this conversion. The installation, cutting the slot in the existing plastic housing, can be funky, but with the right tools, it is doable, and should take less than 1 hour to complete.
My filter measures 10 3/8" x 9 5/8". ACDelco part number: CF193C; GM part number: 23101674
Just Fishing
Can't fix stupid
Utah
I used the dorman kit as well.
I got the one with the reg (cheap) filter.
I really just wanted to keep sand from coming through the vents.
The dorman kit was easy.
Used a razor knife tool to scribe and cut out the opening.
And then used the screw above the center console (didn't put it back kuz pita) to fasten the door in place.
That way everything is the same bolt size later down the road.
And i had the carbon filter in my amazon cart over Christmas.
Wife got a amazon gift card from work and didn't notice it there
So when it's time, I'll do the carbon filter.
On and my ac evaporator looked clogged with dirt/sand.
I did my best to clean it, but i do need to take some proper coil cleaner and attempt a flush later down the road.
And so far, it's awesome.
No longer do i get dust coming through my vents when hauling ass down a dirt trail/road.
I used that exact kit on my 08 Silverado and it worked great. I also like how that filter loads in, the way it bends helps. The evaporator was pretty clean just some leaves.
1BADI5
DMV
I need to do this...........afraid to see how much K9 fur is up in there
Millennium Falcon
CA unfortunately
What type of cutter are you guys using to cut the slot in the housing? I've thought of using a Dremel with a cutoff wheel, a hot knife, or a Rotozip.
I have the cabin filter in my '02 Sub, and I love it. I change it once a year in the Fall when the rains start. It does an awesome job keeping the dust and pollen out. We have miles and miles of orange groves to drive through to get anywhere in the valley, and the pollen really bothers my wife. We use Fram filters with activated charcoal, and she doesn't even smell the oranges when she drives through them.
Geoffsfas10
St. Louis
i dont think a rotozip will fit. they are pretty large, atleast the one i have is. I used a lighter and warmed up a razor blade and it cut right through it real easy. Gave me a nice clean cut too
dremel makes a huge mess.i tried that to start and it flung burnt plastic chunks all over and you have to go just right because too fast and it melts back together, too slow and it melts too much and gets all goopy
Sparksalot
I used a Dremel with a small cutoff wheel. It’s too small really, the disk loaded up with hot plastic pretty quickly. I’m going to try the hot knife when I do theothertwin in a few days.
TheBiznisKitty
TheBiznisKitty
Update: I bit the bullet and ordered the whole kit along with a k&n filter to see if it fit (if not I will just return it). I will let y’all know how the installation process goes and if I see any difference.
St. Louis
I drilled a hole, then used a mini hand saw to make the cuts. Kinda like this one
Tupapi
