George B
¯\_(ツ)_/¯
My favorite penetrant...
Because, F%#k that rusty ****.
Heat did better than anything else in those tests.My favorite penetrant...
Can't be tight if it's liquid! That is a fact!My favorite penetrant...
Actually I saw a test somebody linked here and Aerokroil did worse than PB Blaster, and WD40 did slightly better than PB Blaster at loosening rusted bolts. I’ve been using WD40 forever and find it works at least as good as PB plus it’s good for lots of other stuff.
Well I'm stumped and frustrated. The left front corner lamp lights up as a parking light, but not as a blinker. I changed the bulb, nothing. I changed the headlight wiring harness, nothing. Why could this be happening? A poor ground for the turn signal? How would I even remedy that??
You checked the fuses?
Does your left rear turn signal work?
Ok now I feel like an idiot. I checked all the fuses yesterday and didn't see one specifically for the left turn signal. I checked it just now (thanks to your suggestion) and saw it was partially burned. Switched it out and I'm back in action. Sorry to bother everyone for such a stupid thing!
edit nevermind, lolWell I'm stumped and frustrated. The left front corner lamp lights up as a parking light, but not as a blinker. I changed the bulb, nothing. I changed the headlight wiring harness, nothing. Why could this be happening? A poor ground for the turn signal? How would I even remedy that??
That's exactly what I did. They came right out. I was able to get them out and in with a 22mm open end wrench. But it was an ordeal to snake the wrench in there with enough room to move it. I need to get me one of them socket thingies.Agree, Run the motor for a few minutes to warm the pipes up then hit with PB and they should come right out....
Your lucky.That's exactly what I did. They came right out. I was able to get them out and in with a 22mm open end wrench. But it was an ordeal. I need to get me one of them socket thingies.
Pics or...Loaded up the new wheels into it tonight, they get mounted tomorrow at 8am
The operation was a success and the patient is resting comfortably with four new O2 sensors.
No big glitches I did use the aerosol kroil on top of the WD40 and the pipes on both sides of the cats were hot when applied. Frankly, the clips and push fasteners were as much fiddling as removing the sensors themselves.
The new sensors came with anti-seize on the threads and I chased each bung’s thread with a little adapter that came with my cheapo sensor socket set, so hopefully when the time comes and they need replacing again (which I assume will be sooner than this go around), it will be similarly painless. Actually the biggest pain was the sand getting knocked off the frame and falling into my eyes. I know, I know, safety glasses...
That is all...![]()
The heck with that. Get that patient out and doing some physical therapy!
My favorite post opp thing to do..... grabbing nurses... Most like it anyways....That is the way nowadays. Get 'em up and running, no laying around grabbing at the nurses.![]()
Some will, some wont. Some, do and some don’t. So, you gotta ask them all.My favorite post opp thing to do..... grabbing nurses... Most like it anyways....
