Looking For Advice with Valley Pan Gasket Replacement
Jason in DLH
Cheeseburger and Fries
MN
Thanks to @89Suburban for recommending my oil leak to be a Valley Pan Gasket leak. I’ve looked further into it and it certainly is a problem with the NNBS it seems and will be replacing mine.
With that said...I’m looking for advice in other preventative maintenance items to change while I’m in there. So far, I’ll be replacing these:
-Valley Pan Gasket, and Seals
-Intake Manifold Gaskets
I’ll also clean the throttle body while it’s out and will clean the oil pressure sensor filter since it’s easy access.
Anything else I should change/clean?
2007 Yukon Denali 6.2L L92 with 140,000 miles.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Well, you have no knock sensors to deal with thankfully. What brand of gaskets/seals do you plan to use. IMO, stay with AC Delco or Fel-Pro but others here may have their own opinions on that. Have you seen any seepage at all at the valve covers? Also, IMO, if I was that far in to it I would do the oil pressure sender while apart and have better access. Unless the 6.2 access is not as bad as the 5.3.
Jason in DLH
Jason in DLH
MN
I’m using “Genuine” valley Pan, Gasket, seals, and bolts (all for $60) from PartsGeek as well as FelPro Intake gaskets. I did go ahead and order a new Oil Pressure Sensor since it’s right there. I still have time to cancel the order if the “Genuine” brand is no good (first I’ve heard of them!).
I haven’t noticed any oil seepage around the valve covers at all, so they should be good.
Looks like they're playing off of the "GM Genuine" line of parts, which are the ones that the factory installs. There are other levels of "GM" branded parts, but they're produced by aftermarket companies to be sold at lower price points. I don't see how someone could mess up a valley cover, so it'll probably be fine. Just keep your original, at least for a little while in case something develops. Speaking of, why not keep your original cover and just replace the gaskets?
As far as other parts, I'd get the updated driver side rocker cover (don't forget the gasket(s) if not included) if yours hasn't been updated yet.
For gaskets, AC Delco, Fel-Pro or Mahle have all served me well. Since you'll have it off, clean out the intake manifold. You'll likely have oil puddled up at the back of it. I use a can of engine degreaser and 3-4 cans of brake parts cleaner- the SuperTech brand from WalMart works great and is half the cost of the "skim milk" ones. The oil in the manifold and rearmost cylinders is why we get the updated rocker cover and a catch can. At only 140K miles, you likely aren't past the point of no return, but you're approaching it if you don't act now.
Jason in DLH
Jason in DLH
MN
Thanks for the info. I’m interested to see the amount of oil in the manifold.
I’ll take your advice and swap out the driver valve cover (once I find it).
Definitely will be installing a catch can in the near future as well.
I’ve always used CRC Brakleen...is this “skim milk” to the Super Tech?
donjetman
Valve cover driverside – GM# 12570427 - $117 amazon or rock auto.
We bought our 07 Denali w/6.2 L92 in the fall of 2018 w/130k miles. I'm a DIYer and did the following in the first 6 mths of ownership:
Brake pedal stop light switch - SL1000 - $19 NAPA
Gas cap – ACDelco GT330 $19 amazon
Vapor cannister purge valve on intake – ACDelco# 214-1680 - $18 amazon
air filter, NAPA 22487 - $9
cleaned MAP sensor and throttle body - $1
Catch can, line, fittings - $40 amazon
brake fluid - $6
PS fluid, Amsoil ATF - $6
Frt diff gear oil w/3 pts Amsoil 75-90w - $21
Rear diff gear oil w/4.2 pts Amsoil 75-90w & gasket - $40
Transfer Case ATF w/3 pts Amsoil (ATL) ATF - $16
Transmission fluid, 10 qts, w/Dexron VI, $75
Tranny filter – PTC# F247 - $34 amazon
Torque Converter – Precision P4646 - $218 Nogalitos Gear
Tranny front pump seal – GM# 24237531 - $30 Gunn GMC
Tranny Input shaft seal – GM# 24219390 - $10 Gunn GMC
AFM Deflector – gm#12639759 - $8 Gunn GMC
Main serpentine belt – 6K935 - $19 NAPA
tensioner - $32 NAPA
idler pulley - $22 NAPA
idler pulley - NAPA $16
AC belt – 4K378 - $16 NAPA
tensioner - $28 NAPA
Trans cooler line 1 – ACDelco 15779543 - $16 amazon
Trans cooler lines 2 – ACDelco 25999419 - $56 amazon, but #25999420 is better.
Trans cooler clips- ACDelco# 24205103 - $10 amazon
Trans cooler gasket - $7 amazon
Front lower plastic cowl - $31 amazon
Rear main seal & cover – Dorman 635-518 - $43 amazon
Oil pan gasket – GM# 12612350 - $36 amazon
Oil pickup o-ring – Felpro 72401 or GM 12584922 - $9 amazon
Starter – 6757N - $60 amazon
Alternator (160 amp) – 8301N - $101 amazon
Oil cooler adapter-ICT - $24.99 amazon
Oil cooler adapter gasket – Felpro 72462 - $8 amazon
Cleaned old spark plugs and reinstalled
New spark plug wires, ACDelco 9744RR - $31
Right headlight asembly - TYC 20-6801-00-1 - $48 amazon
Exhaust Manifold clamp, back driver side – APDTY# 028218 - $30 amazon
Exhaust manifold clamps, frt driver side, back pass – APDTY#028253- $67 amazon
Front pass side door handle – 735-6526 - $49 - NAPA
Frt sway bar end link poly bushings - $15 autozone
Frt sway bar bushings – Moog# K200222 - $7 – amazon
Rear sway bar bushings – Moog K6408 - $8 - amazon
Performed TSB 10-06-01-008M that included: changing the driver side valve cover w/# 12570427, installing deflector# 12639759 on the oil pressure relief valve, flushing/soaking all cylinders/combustion chambers w/Motor Medic solvent
Cleaned passenger side valve cover inside and out
Jason in DLH
Jason in DLH
MN
brake fluid - $6
Thanks for the comprehensive list! I was trying to figure out the new PN for the updated valve cover, so that’s very helpful, thanks!
I just purchased a JLT catch can from Summit for $140. :confused:
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Jason I am noticing that cover you picked does not have the solenoid assembly on it. Please be aware they are riveted on at least in my case. Don't want to see you tear it apart for nothing and be screwed like I was. Not sure about the 6.2's never messed with one.
89Suburban
SE PA
Ok I guess the 6.2 doesn't have the solenoids on it? In that case why buy a new cover and just by the gaskets for 1/3 of the price??
donjetman
WOW, that's one expensive catch can. I spent about $40 on mine.
Before I installed the updated valve cover and did the oil consumption Technical Service Bulletin, my catch can would catch 1 oz per 100 miles. Afterwards, almost nothing between oil changes.
Whatever is in the manifold is just what hasn't yet made it into the cylinders.
I don't know if they still have it as an option, but I thought CRC completely went away from chlorinated brake cleaner. Maybe they've changed the formula since then, but I recall it being really weak. I didn't like the idea of paying twice as much for something half as strong. In addition to quickly cleaning, I use it for starting bonfires. So I need the flammable stuff. You just have to be extra careful when using the Super Tech, or any chlorinated cleaner for that matter. But, I'm sure you wear proper PPE when using any chemicals, riiiiiight? :)
There should be a write-up exclusively on this and stickied.
Jason in DLH
Jason in DLH
MN
Yeah...now that you mention it the CRC is different. Didn’t look to close at it the last time I bought it. I’ll try the Super Tech stuff. I really should use my mask with that crap. At least I open the garage door. ;) Thanks for the info!
Oh brother...sometimes I just do dumb things! :yaoface2:
That's kinda why I was asking, but some people just like shiny new parts, even if they'll not be seen. If that new one works for you, you can easily sell your original one to someone here piecing together an AFM delete kit. There's always a "pay it forward", right? :)
Jason in DLH
Jason in DLH
MN
Great idea! I’ll keep that in mind!
marktrafton
The Last time that I bought some CRC at Walmart, they had the original red can spray and the newer green can spray. I definitely recommend the original red can.
Jason in DLH
Jason in DLH
MN
I got to thinking more about this....what was riveted onto where? Did you have to drill the rivets out? I’m a tad confused to this as the videos I’ve watched shows the valley Pan easily pried (or is it pryed?) off.
JamesinAbilene
