Elmerwood
- Joined
- Feb 9, 2021
- Posts
- 17
- Reaction score
- 12
Just watched a few youtube videos all about this which makes me hopeful I can find the issue tonight.Yep, that's about what I meant when referencing the splice comb
Well I tried what @TJ Baker was recommending and pulled the data bus splice comb and checked voltages on the pins inside and found 11+ volts on pin M & B. According to the drawings in the link I shared above M&B are the ECM and BCM. I pulled the ECM cover off and then the removed the electrical plug to find it gummed up on one side with tacky and wet substance. The friend I picked this up from rinsed the engine bay a couple months ago and I bet this was collateral damage. I'm really hoping this is it. I removed the blue cover and you can see the pins are discolored from sitting in this solution for some time. I think I'm going to try to clean it with some electrical cleaner, a brush and some air.
View attachment 270685 View attachment 270686 View attachment 270687
very well written response. Also, right on the money. Had the same (only much weirder random electrical problems) and finally found faulty batterty cables that appeared brand new on the outside. been working great til now. (see my postWelcome to the forum from Oregon. You did not say where you are at but with you going to a cabin, I am going to assume, I hate doing that by the way, that you live where snow is and likely have salt on the roads. The first things I would have checked is part of what you have already done but I would do these checks for ground problems that these NBS rigs are known for. here is a link: https://www.fixmyoldride.com/Chevro...e7e5cd24ed24635&at_ab=per-2&at_pos=3&at_tot=4
Holy Cow! That thing has aliens growing on the connectors. This is why "you" dont power wash the engine compartment! The seals on these connectors are not made for 80PSI+ of streaming water and soap.Well I tried what @TJ Baker was recommending and pulled the data bus splice comb and checked voltages on the pins inside and found 11+ volts on pin M & B. According to the drawings in the link I shared above M&B are the ECM and BCM. I pulled the ECM cover off and then the removed the electrical plug to find it gummed up on one side with tacky and wet substance. The friend I picked this up from rinsed the engine bay a couple months ago and I bet this was collateral damage. I'm really hoping this is it. I removed the blue cover and you can see the pins are discolored from sitting in this solution for some time. I think I'm going to try to clean it with some electrical cleaner, a brush and some air.
