Just Fishing
Can't fix stupid
Utah
Is it AWD? That will help with wheelspin versus the FWD version. I had an 07 then 08 Saturn Relay, loved them. Why two? You remember that washer fluid heater recall...
Oh yeah, she has been working up the sales pitch. :whip:
I'm hearing nothing but reasons why, one of them is for the snow.
AWD vs her Saturn aura's front wheel drive.
That car has the 3.5, and it's a fantastic engine.
Has something like 280k on it now, and it's still running and shifting great...
What i would like is for her to wait for it to start having some actual problems.
but she want's luxury, the tahoe ruined non luxury for both of us i'm afraid. :hahano:
bobsburban
The compressor idea is cool. I've been pondering what to use the spare battery tray for. Only problem is you have to carry a pretty long hose to reach the rears. Still cool, though.
Probably a dumb idea...has anyone attempted to use the Autoride air suspension system as a compressed air source? I read that it holds 80psi.
ARB makes a kit with a 20 ft hose and all the attachments (the T that comes off of the compressor in the photo above is part of it) for airing up everything from tires to basketballs for $50. I ordered it along with the compressor. 20 feet will get to the truck's tires; I'll carry an additional hose I have in the shop that will extend the reach so I can inflate the trailer's tires if I ever have to do so while it's hitched to the truck.
And I don't see any reason why you couldn't plumb a T into the line from the air ride compressor. You'd probably want to run the line from that fitting out to the rear bumper and make your hose attachment point there. I wouldn't want to have to crawl under the truck to reach the fitting with the hose while sitting in mud. Only other issue I see is remotely overriding and controlling power to the compressor while you're using it to inflate something other than the suspension's air bags. I assume 80 lbs is enough pressure in that system to inflate a tire - there's not much volume so that helps.
kbuskill
NE. FL.
Technically it doesn't "hold" any air as there is no tank.
However the air compressor is capable of producing up to 200psi.
With the 1/8" lines, however, it would take a very very long time to inflate a flat tire or even a low tire, plus you would need to hook a switch to the compressor relay to turn it on and also have a way to divert the air from the shocks to the hose you would be using so as not to over inflate your shocks in the process.
The ESCM is programmed to not run longer than 255 seconds (4 minutes 15 secs) to keep from overheating the pump, although with a manual switch it wouldn't shut off, but it would be bad for the compressor.
With all of that being said, the auto leveling compressor for the Trail Blazer SS/Envoy uses 5/32" lines and it has a switch for turning it on manually and a hose for inflating things. The switch and hose was mounted in a cubby hole in the rear of those rigs.
Sparksalot
Bastrop County, Texas
You probably won’t get enough volume from it to inflate tires.
Sparksalot
Lol. Mine did the same to order her new Bronco.
I had an SL2 for a long time. Fun little car. Little being key.
Just Fishing
Can't fix stupid
Utah
There is a smaller version, i don't like it.
Told her she needs something with actual leg room.
Years ago she talked me into a landrover Freelander.
I hit my head every single time i got in it.
We lost our ass on that one, bmw decided to glue in the cylinders and the glue breaks down in the coolant apparently. :rolleyes:
Got the Saturn right after, i made damn sure we got our money out of it.
Nearly 300k miles worth.
:cheers:
I still have to go test the sizing before i stamp my ok on it.
I did tell her we have to wait till late spring or early summer since i hate working on crap during the winter (inspections etc).
Sparksalot
:cheers:
The smaller one is the Buick version of the equinox. You’re gonna feel cramped after the Tahoe.
cfmistry
AMI billet rear badge... I like the look, but not the gap it leaves between the body. Oh well I'll live with it.
High pressure, but low volume output. It's not designed to be ran for very long. If it survived running long enough to inflate a tire, it'd probably only do it once. ALC compressors are about $200- you're much better off buying one better suited for inflating tires for that amount or less.
*EDIT* I see that you were already answered with this. So "+1" for the other replies.
cfmistry
Is that double sided tape?
If so you could get some emblem tape, it is much thinner.
It came on the emblem but yes it looks like standard molding tape. I will definitely look into the emblem tape, thanks!!
Something like this setup?
I think Montana's had them too. @swathdiver would know.
Just Fishing
Can't fix stupid
Utah
And here is the first suspect for the wife,
"CXL" I'm not sure what that is but hopefully that means the upper trim level... :)
Took my neighbor into town to pick up his truck from the service department at the Ford dealership.
It pooped out a part just before I pulled out onto the street. Being the classy and courteous Chevrolet owner that I am, I circled back through the dealer lot to collect my Tahoe's droppings and continued home.
Looks like it needs a bit less fiber in its diet.
Bell housing inspection plate?
Being that dirty? Not from the underside of my rig! lol
bite it, is it gold?
I will NOT put droppings of any kind into my mouth. I'm not Dutch.
It's the butterfly from the unmuffled side of my cutout. It worked loose during my trip to Florida for Thanksgiving. I thought it had completely fallen out long ago. But, no, it has been hanging out and rattling somewhere in the system until this evening. As I suspected months ago, failed welds are to blame. I really don't wanna cut it out, fix it, then weld it back in because it's kind of a POS. I'll likely do like I've been wanting to do and route the unmuffled circuit back into the pipe that exits the rear so at least the sound isn't reverberating under the floor pan. If that's still too loud, then I'll plug off the unmuffled half until I find a better, permanent solution. This will likely be me making my own cutout.
So I have been driving around getting the 200 miles relearn done on the transmission, that only took a week and it still didn't seem right so I went by the shop and he said well maybe it's not done relearning he said to drive it for another week and see what it does today made it 400+ miles and so I took it by the shop something is wrong with the 3-4 shift. He thinks it is either the tecm or a piston in the drum, so it goes back Monday.
Ossipeelake
